Question about Frigidaire FWS833A Top Load Washer
Top loading washer fills when it starts to aggitate it only spins in one direction and over flows
  • 618 Answers
Needs a new transmission.
Posted on Oct 16, 2010
Tries to aggitate but wont everything else works
Sounds like the transmission is out. If it fills up and will pump out while spinning? Then more than likely that is it. Or could be the belt underneath. When it aggitates the belt go's in one direction then spin out it go's the other direction and turns the transmission and drum.
Dec 09, 2011 | Kenmore 24032\24036 Top Load Washer
Washer will not aggitate
LOOK AT THE LIDE SWITCH FIRST WILL IT FILL WITH WATER WILL IT DRAIN WILL IT SPIN IF THE ANSER IS NO TO ALL LID SWITCH IF ONLEY TO AGGITATE MAY BE A TIMER OR AGITATOR IT SELF
Apr 03, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 20842 won't spin or aggitate
Check your motor drive coupler. Tilt washer back against wall and look between motor and transmission . You will see a rubber grommet and two plastic couplers on each end of rubber , They may appear broken or you will see rubber shavings under washer.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer will not spin
you have a bad coupler, it's a $20 plastic and rubber part the connects the motor to the transmission.
Mar 31, 2009 | Kenmore 24032\24036 Top Load Washer
GE WJSR1070A top loader wont aggitate.
You either have a bad timer, transmission, or the agitator is stripped on the splined shaft
Mar 05, 2009 | GE WJSR1070A Top Load Washer
Washer wont aggitate or spin
I think this is the direct drive model, no belt. There is a coupling between the motor and transmission that needs to be replaced. This is a common problem with that type washer.
Dec 21, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer fills, drains instead of agitating, fills, etc
ON THIS MACHINE WHEN IT AGGITATES MOTOR ROTATES ONE DIRECTION, WHEN IT PUMPS OUT AND SPINS IT ROTATES THE OPPOSITE DIRECTION. YOUR MACHINE IS ROTATING THE WRONG DIRECTION WHEN IT FILLS., INDICATING THAT THE TIMER IS SENDING VOLTAGE TO WRONG WIRES. SOLUTION , REPLACE TIMER.
PS: MAKE SURE ALL WIRES ARE PLUGGED IN TO MOTOR. WHILE THIS IS UNLIKELY , I HAVE SEEN THIS BE THE PROBLEM.
FXIT
FXIT
FXIT
Nov 24, 2007 | Admiral AW22 Top Load Washer
Frigidaire FWS833A Top Load Washer Logo
24 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
