Question about Worx Electric Blowervac With Carrying Case 644515
Can I run this without the bag attachments if I am only blowing the leafs to a pile?
  • 760 Answers
You can use it for blowing without the bag. You should have the bag in place for vacuuming and have the zipper closed.
Posted on Oct 16, 2010
Where do I attach the bag for the vacuum?
When the machine is converted to vacuum mode, the collection bag will go on the machine where the blower tube (long part) is connected for blowing mode.
Mar 19, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
I inherited two different blowers. i can't see how the only bag i have can fit on my weed eater barracuda 2595 and can't find any diagrams on line. once i open the spring door the bag doesn't really fit...
OK this may seem difficult but its really not. The spring door there are only 2 things to do with it open. Either you put in the round circular attachment and then close the door or you attach the bigger of the 2 "funnels."
The big funnel is used to **** up the leaves and it will NOT work WITH that circular attachment attached. The Barracuda will NOT blow leaves without the circular attachment.
If you want to blow leaves, open the swing door, put in the circular piece with a twist to keep it in place, close the door and attach the smaller "funnel" to the smaller opening on the front side of the blower.
If you want to **** up leaves open that swing door, take out the circular piece HOLDING OPEN the swing door and in that same place attach the larger "funnel". Where the smaller funnel goes is where you attach the bag! There should be a small opening in the bag with a velcro strap. Put that over the opening of the blower, attach in place with the velcro and your ready to **** the leaves! When putting on the bag, make sure the bag shoulder strap is facing the top of the blower, not the swing door.
Hope that helps. Now on to find the solution to my problem!
dlandlrd
Oct 30, 2010 | RTO Weed Eater Electric Barracuda 2595...
I have a Black and Decker BV1000 Type 5. It is quite old but and I bought it from a guy. Question: how do you change this thing from Vacuum to blowing?
If you got it without the box and it is set up only as a blower then you are missing two parts. The bag attachment which attaches where your blower tube is now and the input nozzle which is like the blower tube you now have only larger. It goes on the air intake, where the orange cover is now. Grab a manual online although I doubt it would be cost effective to try and buy the missing parts.
Oct 21, 2010 | Black & Decker & Leaf Hog Blower / Vacuum
I have a Challenge GBV180 Garden Blower Vacuum. I can only get it to blow ..does this model vacuum and if so how do the bits attach ?
remove the blower tube by turning anticlockwise. remove cover from air inlet same way. attach large diameter suction tube to air inlet (has to fit correctly as this is where the safety switch is) attach collection bag to air exhaust opening (where you removed the blower tube from)
Oct 15, 2010 | Garden
Need to know how to attach vac bag
The bag should fasten to the blower where the blowing tube comes out. (blowing tube is removed to install the bag, and a pick up tube is installed on the 'screen door') It should have a tightening strap or velcro to hold it in place.
Nov 09, 2009 | RTO Weed Eater Electric Barracuda 2595...
It vacums but will not blow
If it vacuums, it is working. The blower tube goes where the bag attaches. Basically, the machine sucks from one end and blows out the other. You just use the end based on your job. Rather than **** leaves in, it pulls in air and where the bag attaches, that's where the high speed air blows out. Hope this helps.
Oct 25, 2009 | Ryobi Garden
Cant get bag to go on
Yes the bag attaches to the same small diameter that the blower tube is attached to. Loosen the knob and remove the long tube. Put the ring with the tightening knob on to the small opening in bag and slide it over the opening. tighten it down. Then take the large tube and attach it by opening up the motor access door.
please mark this as a fixya! thanks
Mar 14, 2009 | Homelite 'Yard Broom' Leaf Blower
Craftsman leaf blower/vacuum
There is a round grille on the bottom of the unit. Insert a flat blade screwdriver into the latch to release it and reveal the vacuum opening. You should have a two-piece intake pipe that will attach to the opening.
The collection bag attaches to the smaller outlet where the blower pipe used to be (unscrew the wing nut to release the blower pipe). The bag clips onto the hooks at the base of the opening.
Nov 11, 2008 | Craftsman 4 Cycle Blower/Vac
Leaf Blowers Features
* CFM (cubic feet per minute) is the measure of vacuuming power. Ratings fall in the 350 to 600 CFM range. * MPH (miles per hour) measures blowing. Leaf blowers perform at levels from 125 - 210 mph. * Decibels (dB) is the noise rating. * Reduction ratio on mulching blower/vacuums calculates how many units of leaves the mulcher can produce. A 10:1 ratio means that 10 bags of leaves can be reduced to 1 bag of mulch. * Speed settings allow better control when blowing or vacuuming. * Attachments, such as extension tubes for cleaning gutters, are available separately.
Aug 27, 2008 | Craftsman Blower Attachment
Vacuum or Blower?
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Aug 27, 2008 | Toro Lawn Mower With Toro Power Tools
Worx Electric Blowervac With Carrying Case 644515 Logo
139 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
