Question about Navman Tracker 5505i Color Chart Plotter 5" C-Map Max by GPS Receiver
Gps fix We have a 5505i situated under the window of our wheelhouse on our boat. Several times a day, we can lose our fix. Most times, we can turn the unit off, and then turn it on, and it would find the fix straight away. But then you have to reset the 'go to' again. At other times, the fix takes 20 to 45 mintues to re-establish a fix. Most inconvenient at times when you are manuvouring around islands, rivers, etc. I have tried to contact Navman Australia, but have been unable to get them either on the phone or by email.Have you any suggestions? Can I attach an external GPS mouse to my unit, like the one I can use for my computer.
    Genius:
  • 2,035 Answers
You need to connect a external antenna to your unit which will be out side on the boat which will give proper signal to your unit ,IT may resolve the problem
Yes you can connect the GPS mouse to your unit but make sure it is compact able with your unit .............
Posted on Jun 03, 2008
    Sergeant:
    Champion:
  • 359 Answers
Http://www.livorsi.com/pdf2/NAVMAN_T5505_5605_manual.pdf im not sure if you have the manual but there are some suggestions within it see link above
    Genius:
  • 3,587 Answers
Do you have anything interfering with that signal, like a solid mass of metal?
  • Patrick Michaels
    Patrick Michaels Jun 03, 2008
    well..sure..but you might want to make sure that mouse is water resistant at the least.
Premature power down.
Check for loose or corroded power connections.
Jul 12, 2013 | Lowrance LCX-113C HD GPS Receiver
We set it up and ran it before installing it on the very top of our new boat. It was running fine for a day or two. Then the next time we turned it on we got a error code 6. What does it mean, and how do...
I would get on the Mfg. website, customer service dept. and tell them the problem. They are usually very helpful and you may be able to download a solution on a laptop, wireless computer, then take it to your boat and upload into the GPS. It's worth a shot.
Nov 28, 2010 | GPS
My Raymarine C 120 GPS intermittently stops working.
I had to replace a GPS antenna unit with cable. Sometimes, during bad weather or strong sun, I lost FIX on satellites. Cleaning the top of antenna did not help. Unit from Ebay was also a junk. Get a new one after testing display on a friend boat.
Jul 28, 2010 | Raymarine C120 GPS Receiver
My LMS-522C keeps losing it's position on the GPS.
I'd suggest calling Lowrance.. Those guys are very helpful with step by step support... I just purchased a used boat with a 525c df on it and been troubleshooting some problems with it. Central time zone and best to call right when they open or turn on the phones at 8:15.
Mar 07, 2010 | Lowrance Lms 522c 5" Screen Color Internal...
I have a navman 5500i tracker ,the zoom isnt coming up far enough to show water depths and hazards by pushing the + - button .is there an easy fix? Thankyou Muzza
Just got the same one and same problem, I also have a 5505i and is only zooms in close when i put in the c-map chip and it zooms close in the chip area only?? now i have a chip for the 5500i and it zoomed in but only on the Texas part of the map, that is the chip it came with, but i live in Canada. Be carefull the c-map max chip for the 5505i is not compatible with the 5500i it needs c-map nt+ chip. 5500 chip is black 5505 is orange
Jan 19, 2010 | Navman Tracker 5500i GPS Receiver
I'm on my second nuvi 255w. As before this ine has
I am in the same boat as you.. I am on my 2nd 255w unit as well. The first one lasted 2 weeks. This one about 45 days. The thing I noticed, which may be coincidence, is I updated the software and map a couple days prior on each unit before problem occured. Last night the 2nd one lost satelite for about 5 hrs, an area I deliver pizza's in everday with no other problems. No mountains, no tall buidlings, yet I decided then to power off unit completely, stand outside and turn unit on. I waited about 10 minutes then put 255w back in vehicle in which at that time still was not working. But 30 minutes later when I got back into vehicle it was working again for the rest of the night. Not sure if standing outside corrected or not, but it is working again. I would be curious to know if the software update and map update plays a part in the problem.
Sep 25, 2009 | Garmin nuvi 255W GPS Receiver
Yes my northstar 6000i keeps losing gps signal
how old is you Gps antena ,with a older one it can happen that they lose fix
Where is the Gps antena fixed inside the boat or outside
Allway try to put tha antana outside. abou 20 % more signal
Look after the antenakabel if the kabel is a little bit broken water coms inside thae kabel an the signal gets lower.
Aug 27, 2009 | Northstar 6000I GPS Receiver
Our e120 has no boat recognition. We cannot make it find our boat in order to use it.
Do you have fix on the GPS?
Have you selected "find boat" and not "cursor" (bottom left button under the screen)? If you'r still stuck try a master reset (factory reset) by going into the menu and select system setup - factory reset.
Jul 31, 2009 | Raymarine E120 Multifunction GPS Receiver
Problem getting a proper fix
The antenna should be replace by raystar 125.
Regards
Michel
May 31, 2009 | Raymarine RL70CRC GPS Receiver
My garmin nuvi 200w sat nav keeps losing the gps signal. I've done a manual reset and used the webupdater to ensure the software is up to date but still it keeps losing the gps signal
There are a few options for you...
1. Check to see under what kind of conditions the GPS loses it's signal. If there are tall buildings, is a cloudy day etc or even the position of the GPS in the car (does it have a clear sight of view of the sky)... In the latter case, you could change the position of the GPS where it gets a clear view of the sky. For Cloudy days, better have a map ready or preplan the route using mapquest/googlemaps, as nuvi 200 series is especially notorious for these type of situations. For tall building problems, what I do is (c330, not nuvi), just tap the route displayed on the top before the signal gets lost and memorize the next few upcoming turns. Or avoid downtown (where those huge skyscrapers are)
2. If you have enabled WAAS setting in the settings menu (it should be somewhere under "GPS mode", disbale/uncheck it and use the normal GPS mode. WAAS may provide you a more accurate position, but at the expense of some avaialble satellites.
3. Or your GPS may have a genuine problem, then your only recourse is to call Garmin and talk to them. Here's the contact info:
Support North America
(for all Garmin products except Apollo aircraft)
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
Email Product Support: TechSupp@garmin.com
Product Support Phone
1-800-800-1020 (U.S.)
1-888-442-7646 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
Good Luck. Personally I would avoid the 200 series and go with the 3xx, 6xx or even better the 7xx series (if you need all the bells & whistles)
Jun 07, 2008 | Garmin GPS
Navman Tracker 5505i Color Chart Plotter 5" C-Map Max by GPS Receiver Logo
251 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
