Question about Yamaha R-V703 Receiver
I have a yamaha R-V703 receiver and it has worked well until today. It was turned up loud and all of a sudden kicked off. Now every time it is turned on and the volume knob is turned it turns the unit off. What could be the problem?
Make sure the speakers are connected correctly. Something inside overloaded and could have blew a fuse or is in protection mode. Before taking the unit in for servicing or attempting to opening it, I suggest checking that the speaker wires are connected correctly to your receiver in the back. Even one loose strand of speaker wire touching the steel panel will shut your receiver off when the volume is turned up. If that isn't the problem, then try to unplug all the speakers and test it again to confirm that the speakers are not preventing the receiver from functioning properly. Lastly, if no success, wait a while until the unit cools then try again without speakers connected.
Posted on Oct 16, 2010
Yamaha HTR-5063 is connected with new LG smart TV with HDMI. Today no picture or sound on TV. How to fix it ?
First, you need to identify which box the problem is in. Does the TV work with other inputs? If not, problem in TV. If it does, then the problem is in the Yamaha.
Once you know where the problem is, you can proceed to fixing what's broken.
Jul 10, 2015 | Yamaha HTR-5063 Receiver
The Sub-woofer output on my Yamaha HTR-5440 keeps dropping out!
may be dry joints on electronic components, consult a technicia for resoldering the pre amp or amp unit,
Feb 03, 2014 | Yamaha HTR-5440 Receiver
I lost some settings in the volume menu and sub volume
did you blow a fuse, or did you blow out your speakers.
Jan 30, 2013 | Alpine iDA-X100 Car CD/ MP3 Player
Receiver suddenly turns off
If you have the vollume control set around 40, End watching a movie if there is a loud burst in vollume,It is causeing the reciever to run over it,s wattage rateing. End over heating,When it,s shuts down, It went into what is called the protection mode.Keep it at a lower vollume then it willnot do that.Allso what can cause it to do that, If you have your output leval control on your sub turn right up.
Oct 17, 2012 | Yamaha RX-V665 Receiver
Connect Yamaha R-V703 receiver to HDMI or Optical output on TV to get 5.1 sound
In your quest for:
it may not only adaptors that you need:
• you may need a Digital Audio Decoder for HDMI
like the one from:
http://www.gefen.com/gefentv/gtvproduct.jsp?prod_id=8202
Since the model of the TV is unknown (not stated above)
• which should be connected to a device with ATSC tuner ( OTA )
Channel Master 7400 PVR
like the one from :
http://overtheair.saveandreplay.com/channel_master_7400_PVR.asp
http://www.channelmastertv.com/
• you may experience, little to no output from the rear speakers,
and many times only the center speaker will be active.
But on action movies,
you may hear all 5 speakers + 1 ( for sub) all of the time.
For viewing:
use the TV as a monitor (also unknown model, not stated )
hope these helps
thanks for choosing Fixya for assistance
Sep 08, 2012 | Yamaha R-V703 Receiver
Running loud on very hot day it stopped working and will not turn on again, power it available at rear outlet when switched on but no activity from rv703
You know the answer.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 06, 2011 | Yamaha R-V703 Receiver
Power on but no sound
check for a clicking sound of relay after a few seconds from switching on, if missing , the amplifier section needs technical attention. refer service to a qualified engineer.
Nov 14, 2010 | Yamaha R-V703 Receiver
No sound
No easy answer given this clue.
Nov 18, 2009 | Yamaha R-V703 Receiver
Yamaha R-V703 Receiver Logo
189 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
