Question about Samsung HP-R4272 42 in. Plasma HDTV
Black Line on Samsung TV Model # HPR-4252
Hello there. I have a Samsung model # HPR-4252 which suddenly has a black line running from top to bottom of the screen on the extreme right side. What should I do to eliminate the line?
    Genius:
  • Samsung Master
  • 1,689 Answers
This is a screen address failure from part of the matrix addressing. This can be caused by fair number of types of faults to cause a missing part of the addressing. You will not be able to fix this yourself.
Find out who the authorised local Samsung service is for your area. They will be able to give you an estimate.
Jerry G.
Posted on Jun 03, 2008
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
My 46" Samsung TV (model
All plasma and LCD ts have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken.
I hope this will help in solving the problem....
May 10, 2011 | Televison & Video
Horizontal black line running entire screen an 4 more lines running vertical
Hello
This type of fault in Plasma TVs are of power supply regulator capacitors. If any one of these DC capacitors, go low in rated value, proper smoothin of DC power does not occur. and black bars across the screen fro top to bottom will be the result. Just check for any capcitors of it power retulator side for bulged out or leaky. You have to open the TV to see whethere there is any of them is damaged. OK.
Jan 30, 2011 | Samsung 50 in. Plasma TV
Turn on my tv samsung HPR 4252 and I get no sound or picture
DOES THE TV TURN ON , HAVE YOU TRIED OTHER SOURCES LIKE DVD ,DID YOU CHECK YOUR HDMI CABLE IF ALL OF THIS SEEMS GOOD IT LOOKS LIKE A DEFECTIVE MAIN BOARD REPAIRE ABOUT 325 DOLLARS
May 31, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HPR-5052X Plasma issues. Recently started
If the picture os goint to lines right from the midpoint downward then most likely you will have to replace the lower y-buffer board part number BN96-02027A. The board is mounted on the left side of the plasma panel when you take the back off. The upper y-buffer board sounds like it is failing as well and this was a very common issue on the older Samsung plasmas. The part number for it is BN96-02026A. Please take a moment and rate my answer. Thanks...
Nov 26, 2009 | Televison & Video
Samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
May 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Thin black line
Try to replace the YSCAN board. If not fix it, then it's the PDP Panel failure.
Jan 07, 2009 | Samsung FPT5084 50 in. Plasma HDTV
I have a plasma tv need help
Sounds like panel is bad or driver ic is bad on the board directly below the black line. Good luck on the repair. Any questions, we can do a chat and go from there. GURU JAY
Mar 14, 2008 | Televison & Video
Large black line top to bottom
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Oct 26, 2007 | Samsung HP-R4262 42 in. Plasma Television
Open Questions:
See all Samsung HP-R4272 42 in. Plasma HDTV Questions
Samsung HP-R4272 42 in. Plasma HDTV Logo
474 people viewed this question
Jerry Greenberg
Jerry Greenberg
