Question about Cell Phones
When our Dukane intercom system was first installed, it was integrated with our outside line digital system and outside calls could be made from the Dukane system by dialing '9'. Our Dukane system blew out after a tech zapped it and the company had to replace the main board under warranty. After several joint vendor visits, the Dukane phones still cannot be used for outside calls...any thoughts?
Bajanguru
  • 7752 Answers
SOURCE: RAZR V3 GSM won't let me dial out! Help!!
have the phone's firmware reflash on the phone
Posted on Apr 14, 2008
cnavarro
  • 2460 Answers
SOURCE: Speed Dialing KX-T7453
Part of the number you store in your speed dial has to include a "9" or 8x access code to get an outside line.
Carl
Posted on Sep 18, 2008
  • 479 Answers
SOURCE: The phone is constantly showing
if its in warranty you can get it replaced as it counts in the parts replacement warranty.but if the warranty period is over it is compulsary to pay and get it repaired.
also check for the small antenna connection in the device which catches the frequency if that is faulty the same problem can occur.and that replacement will be more cheaper and that could also be repaired.so consult some other mechanic for that problem also.
Posted on Sep 24, 2008
  • 18 Answers
SOURCE: meridian M7310 intercom key not working on anyphone
Do Feature **CONFIG, go to CONFIGURATION, select the second option, should say Line something, keep scrolling and it will say I/C: #,. press change, you can have a max of 2 Intercom keys, if you need other info, go to youtube.com and search for "thenortelguy"
Posted on Oct 01, 2009
SOURCE: Hello, My I phone 3G
I have and iphone 3g and my applications are not working, as soon as I tap on them they open for 2 seconds and they close down, the only ones that work are the ones that came with the phone.
Posted on Oct 14, 2009
Uniden dect 6 0 manual
Try pressing the intercom button (base) above the number 1, on the handset the intercom button is below the # button.
Intercom?
Whenever the phone is in standby, you can make an intercom call
between stations without using the phone line.
You can make an intercom call from any station, but only two stations
can be in an intercom call at any time.
If an outside call comes in during an intercom page, the phone cancels
the page so you can answer the incoming call.
?f an outside call comes in during an intercom page, the phone cancels the page so you can answer the incoming call.
If an outside call comes in during an intercom call, press
speaker on the base or talk/flash on the handset to hang up the intercom call and
answer the outside call
see page 15/16 of the manual at the link below.
http://www.uniden.com/pdf/D1688-2om.pdf
Sep 03, 2014 | Uniden D1688-2 Dect 6.0 1 Corded 2...
Why do I need to push a line to dial out
Since the system can make both intercom calls and external calls it is factory programmed to consider a number dialled to be intercom hence need to pick a line before you can make an external call. However it is also possible to program your phone to automatically access an outside line on lifting your handset in the installation manual
Feb 27, 2014 | Panasonic KX-T7730 Corded Phone
Landline phone constant busy signal
should you dial 9 or another access code for outside calls?
If if you dial an "outside" number on an intercom line it will look at the first 2-3 digits as another extension. You need to dial the Central Office access code, or use a line key assigned to an outside line.
Jan 17, 2014 | NorStar Lands Phones
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
Jun 15, 2011 | Uniden D16602 Twin Cordless Phone
I have a Dukane MCS350 intercom system, everything works on the system when bottons are pushed, however there is no sound from any speakers... when you call a room, it states the room number with a...
A room number preceded by a 'P' indicates the room is in privacy mode. This could be the room switch is in privacy mode, or there is a wiring issue. In this mode, the room can hear calls/pages, but you cannot hear the room from the console.
If the room cannot hear pages/calls, then you have a wiring problem.
Jan 10, 2011 | General Electric Lands Phones
How to use the intercom system
  • Check your telephone to see if it has an intercom feature. Many wireless phones that come with multiple units allow you to temporarily turn one unit into an intercom to contact other units attached to the same wireless phone system. Depending on the model, you can contact all the other phones at once, or a single specific phone, by pushing the intercom button and entering the other mode. To put the phone back into regular mode, all you have to do is switch off the intercom option.
  • Contact your telephone provider. Some telephone service providers allow landline phones to call themselves, which enables the phone to function as an improvised intercom. You would simply pick up the phone, dial and then close the connection. Once the phone is answered elsewhere in the house, you will have established a line to another phone and you can speak normally on it. This has largely been eliminated due to lack of need as technology advances, but it may still be an option with some providers.
  • Purchase and install an intercom system that will work through an existing phone line. Many of these products, some of which are produced by Panasonic, operate as a halfway point between a traditional intercom system and a phone line. The exterior intercom links directly to the phone line, and you can pick up the phone and talk through the intercom unit outside once the system is properly set up
  • Dec 18, 2010 | Uniden Cordless Phone
    Is there a way to disallow all outside calls and
    You could just remove the lines off of that extension:
    1.Go to extension 10 or 11
    2.Press (feature) (0) (0) (left intercom) (left intercom)
    3.Press #301
    4.Enter the extension # you want programmed.
    5.Enter the line you want removed (line 1 =01 line 2 =02)
    6.Press 2 to remove that line
    7. Repeat steps 3-6 for all lines you have on that extensions.
    Hope this helps!
    Sep 01, 2009 | Lucent PARTNER18 Corded Phone
    Meridian M7310 intercom key not working on anyphone
    Aug 28, 2009 | NorStar Meridian M7310 Phone
    1 lines is ringing & another is not ringing
    Somewhere you should have a programming and operating manual for your phone system. Typically in a Panasonic you turn on CALL WAITING for both Intercom and Outside lines via a code you dial at each phone on the intercom (7311# 7321# for a TA).
    This is assuming that the lines are already programmed to ring at the phone.
    Carl
    Aug 21, 2009 | Panasonic KX-T7730 Corded Phone
    Cell Phones Logo
    94 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
