Question about Dimplex DS5603 Heater
This heater was purchase less than a year ago. This year I tried to use it and the heat and blower only work for a few minutes and then quit. Does anyone have an idea of where I could get this repaired, since it's still under warranty?
  • 279 Answers
Take it back to the dealer you bought it from!
Posted on Oct 16, 2010
  • wyldpeach Oct 16, 2010
    I purchased it at Fred Meyers. The store will not take it back. I need someone that is authorized to do warranty work on it. I live in the Seattle, WA area.
  • eldee Oct 16, 2010
    Call the manf. They should be able to tell you how to get a warranty repair. Good luck...
I have a nearly new briggs and stratton 800 snowseries snow blower that was purchased about 5 years ago. Used less then 10 times with no problems. It sat the past few years and still looks really clean....
Most likely the carb is varnished up. Gas sitting too long will go bad and will gum up the carb jets, valve seats, etc. Rebuild the carb, and it should run. If storing for long time make sure to add fuel stabilizer to the gas, run the unit for ten minutes, shut fuel off let it run until it quits, then put in storage.
Nov 10, 2014 | Measuring Tools & Sensors
I need to know hoe to fix my heat in my 95 Camry LE...
You may need to replace the blower motor.Even a new one can go bad. I would try that first unless you get a professional with testers.
Nov 19, 2017 | Heating & Cooling
No air/heat coming through vents
u more then likely have a bad blower motor resistor
Jun 20, 2013 | 2000 Chevrolet Blazer
The blower fan comes on several minutes before the
Bad fan switch. It may also be called a fan limit switch. If your furnace is less than 5 years old, the switch is part of the circuit board and you will need to replace the board.
Jan 11, 2010 | Heating & Cooling
I have a Ruud Silhouette II that is just over 5 years old. It will kick on for a few minutes, then I'll hear the burner kick off for a few minutes while the blower stays on. Then it will light again and...
Are all your supply vents open? The furnace may be oversized or have a air blockage. Have you always kept the filter changed. Newer heaters need the ducts sized right. If the new unit has worked great in the past then it's probally not the duct work.
Jan 03, 2010 | Heating & Cooling
Nt mimimax heater showing error message and wont heat water.
the blower may get damage even if you do not use it buy a new blower and install you self it only take 30 minutes
Sep 04, 2009 | Pentair Minimax NT Heater
Iron quit working in less than 1 year.
Bought my Shark G1400Z iron about a year ago. The iron caught on fire. Luckly I was only out of the room for a few seconds. What can be done about this?
Apr 05, 2009 | Euro-Pro Shark GI490 Iron
Heater runs hot for a few minutes then stops heating
I would say from what you have described your problem is a bad thermostat heat sensor (you may have to replace the whole thermostat on this model!) This is a very common problem for this unit!
Please rate my sesponse!
THANK YOU
Jan 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Goodman PGB042100-1 REVA Flame sensor not working; no heat
try national energy they will give you a price you will need make model and serial number 600 is high you should be able to get it for a lot less
Jan 07, 2009 | Goodman GMS90703BXA Heater
I have a monessen LPG fireplace and the blower motor has seemed to stop working. it has a variable rotating switch on it. dont know if anyone knows where this problem is on most models like this?
The problem is likely the fan motor for the forced air blower, which means the entire blower needs replaced. The description of the problem is the same problem we had approximately two years ago when our motor was still under warranty (less than a year old). In our case the motor was replaced without charge. However, the same problem has happened this year which is extremely disappointing since we only run the fireplace from December to April intermittently because it is only a supplimental heat source for the house. You can either look up the model number and part number and order a replacement over the web (less expensive if you are DIY and know what you're doing) or see if the local LPG supplier can repair the part or replace. Good luck.
Dec 06, 2008 | Stoves Monessen Variable Thermostat...
Dimplex DS5603 Heater Logo
88 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
