Question about Panasonic PV-DM2799 27 in. TV/VCR/DVD Combo
Panasonic TV model # CT2733HSF - I can not get it out of hotel mode - have tried various button combinations suggested by mfr both in online manual and in email suggestion, including simultaneous hold of Options and Power buttons; options and channel up (or channel down); option and volume up (or volume down); etc etc - all to no avail... any ideas?
techman
  • 3130 Answers
SOURCE: My TV Says Line and Displays Just One Channel
Unfortanatly, your gonna need the original remote or a simular one to get to the channel programming mode in the menu. You can go to http://remotes.com or call 1-800-remotes and get one for your set. Im sorry i couldnt assist you more. Good Luck
Posted on Jul 12, 2006
  • 81 Answers
SOURCE: TV Won't Power Down; Change Channels; Change Volume; etc
sounds like maybe the remote contol is at fault.Do the front panel buttons work?
Posted on Jun 11, 2007
  • 4 Answers
SOURCE: No display with DVD, VCR, or tuner
It sounds to me without knowing the model or type unit that you may need to unplug tv AND take batteries out of remote for a few seconds, replug and start over. Hope it helps
Posted on Aug 06, 2007
SOURCE: Blown fuse on panasonic tv
Maybe the horizontal output IC are on short circuit.
Posted on Nov 04, 2008
SOURCE: no sound on various channels. One channel is
Disconnect from power supply for about a half hour. The set will reset itself.
Posted on Aug 30, 2009
Somehow my 2014 toshiba TV set put itself in hotel mode.. how do I get it out of hotel mode
If your operators manual isn't handy you can download one online by googling your TV model number.
Jan 18, 2018 | Toshiba Televison & Video
How do i get my panasonic th37pr9u out of hotel mode....i have tried a few things i found online but no remedy has worked.
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the V/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above
Read more: I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don`t have the remo... - I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don t have the remote control :: Ask Me Fast at http://www.askmefast.com/I_just_purchased_a_Panasonic_TH37PG9U_TV_from_a_hotel_and_cant_get_it_out_of_hotel_mode_How_do_I_get_into_normal_mode_But_I_dont_have_the_remo-qna9315338.html#q5576553 you need your remote,this is the one you need,maybe you can find it cheaper,https://www.amazon.com/OEM-Panasonic-Remote-Control-TH-37PWD8BK/dp/B00NRHAZDU
Apr 21, 2017 | Panasonic Televison & Video
How to get Sanyo dp50741 out of hotel mode?!
This is for Panasonic but might help you
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the AV/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above.
Read more: My 50" sanyo plasma tv is stuck in hotel mode how do i get it out of hotel mode? - When i turn the tv on it says D01--32 and a blue lower case u under it :: Ask Me Fast at http://www.askmefast.com/My_50_sanyo_plasma_tv_is_stuck_in_hotel_mode_how_do_i_get_it_out_of_hotel_mode-qna4904417.html#q5129429
Nov 28, 2015 | Sanyo Televison & Video
How do get TV out of Hotel Mode? I have a Panasonic TV Model TH-32LRU20
Change remote batteries. Unplug set and replug it after 5 min. that should reset the devices. If that doesn't work, check the manual that came with the set or go online to Panasonic and look for user guide.
Jul 14, 2015 | Panasonic Televison & Video
How do I turn off demo mode
To exit the self-demo mode, with the TV on, press and hold Play/Repeat for 5 seconds (possibly a bit more). If you press and hold the button again, you will go into the demo mode. Panasonic has the manual at their support site: http://www2.panasonic.com/consumer-electronics/support/Televisions/TV-Combos/Operating-Instructions/model.PV-C1320.O . The direct link to the manual is http://service.us.panasonic.com/OPERMANPDF/PVC1320.PDF .
I hope this helps.
Jun 11, 2011 | Panasonic PV-C1320 13 in. TV/VCR Combo
I bought a Panasonic 42" Plasma th-42pwd8 from a hotel. The monitor had the menu, and channel buttons disabled through "Hotel mode". It did not come with a remote. How do I unlock the buttons?
If you cannot find the remote control at all, you will need to reprogram the EPROM IC. This IC is inside the tv, with numbers starting or in between 24c02.... Please contact any qualified tehnican for further help. The IC i mentioned is programmed and at present it is locked through Hotel Mode. Also try to look RESET switch, to reset the whole unit. Thanks
May 15, 2010 | Panasonic TH-42PWD8 42 in. EDTV-Ready...
Can't exit hotel mode on Panasonic CT-2552HE
you will need the panasonic remote..
hold down the V/- button on the television. Then press the AV button 3 times on the Panasonic Remote. This will bring up the hidden menu for you.
hope this helps
Cheers
Little Dish Fitter.
Aug 21, 2009 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
CANNOT RETUNE THIS TV BUSH TV DVD COMBO LY2211WCW
Press menu button then press 7935, if like me you bought a display model it will be set to hotel mode, this hides all the menus, once accessed switch hotel mode off, job done x
Jun 11, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Getting out of hotel mode
hi have crown tv modle number ctt20001 i think it is stuck in hotel mode
Feb 20, 2009 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Open Questions:
Panasonic PV-DM2799 27 in. TV/VCR/DVD Combo Logo
101 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
