Question about Compaq Armada M700 Notebook
Touch pad is not working
I have Toshiba Satellite U305. My touch is not working at all. I used FN F9 to enable but it is not helping too, would please help me to fix this?
    Genius:
  • 3,587 Answers
Check settings under control panel first..if not there, get drivers from www.hp.com and then, if that does not get it done, then you're a candidate for a palm rest replacement.
Posted on Jun 03, 2008
My cursor on my laptop in stuck in the middle of the screen? my daughter i think my have pressed a few buttons?
You can re enable touch pad easily, some models of Toshiba has a switch between touch pad and space key, or you can enable it by pressing fn key and f9 together (or you can find near to it )
please vote for me if found useful ... Thank you
Aug 27, 2011 | Toshiba Satellite Pro L300 Notebook
My mouse pointer not moving if i use touchpad, but if i use usb mouse it works well.
Try to press Fn (locate at the bottom left of the keyboard near CTRL )and at the same time tap F9 (on top of the keyboard), you will see the status if it's enabled or disabled, just tap F9 to make it enabled.
Feb 24, 2011 | Toshiba Satellite L455DS5976
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
The mouse touch pad doesn't work
Fn+F9 is the hot key for enabling or disabling the touchpad
Aug 20, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Laptop Satellite A15-S157 Mouse Cursor stuck in one place(Locked)
To get enable or disable the Touch Pad you have to pulse the Fn + F9
You can also set this function as follow:
Start >> Control Panel >> Printers and other hardware
Click Mouse >> Touchpad (enable or disable)
Oct 27, 2008 | Toshiba Satellite A15-S157 Notebook
Frozen touch pad
Hold down the [Fn] key and then press the [F9] Key to toggle touchpad on and off
On my Toshiba Satellite 1135-S155 Fn key is in the middle of Control [Ctrl] and Alt [Alt]
Oct 02, 2008 | Toshiba Satellite 1135-S155 Notebook
Toshiba Satellite A85-S107 laptop touch pad L-R key not working
try using the fn and f9 to enable or disable the touchpad.
Jun 27, 2008 | Toshiba Satellite A85-S107 Notebook
HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE PRO M15-S405
Press the Fn and F9 keys, that should turn it back on. Let us know if that solve your issue and please dont' forget to rate this posting.
Feb 09, 2007 | Toshiba Satellite Pro M15-S405 Notebook
Compaq Armada M700 Notebook Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
