Question about Cerwin Vega CLSC-15S Subwoofer
Cerwin vega cls15 woofer material? - Cerwin Vega CLSC-15S Subwoofer
JULIANFIX
  • 975 Answers
SOURCE: Cerwin Vega V-35 Horns Drivers Model TMH-1
first you need a multimeter set to OHM , check on the back of the horn , remove the leads and do some reading , it should read 4 , 8 , 16 ohms depending of the brand , if you get no reading its means that need to be replaced , some horns you can detach the back (magnet w/the coil ) so you can replace it without buying the whole unit . good luck
Posted on Apr 19, 2008
tech48
  • 624 Answers
SOURCE: cerwin vega at60 and dc1515
It is called "dry-rot" and it happens with age to paper cone speakers. I am not aware of any products made to help prevent this problem. But you can always replace the woofers with new one's or find a place that "recones" speakers and that would solve your problem for a long time. If you have rubber surround on the cones, it would take much longer to have any type of dry-rot problems. The "foam" type of surround on the cones is the worst for this problem. Most new woofers have polypropelyne surround of the cones and it would probably outlast you, so replacement with a good quality woofer really is a good option.
Posted on Jul 08, 2008
SOURCE: i have a set of cerwin vega ls-12 3way woofer works but tweeters
thanks for replying so fast "oilcitycompu", i will do that .will let you know if it worked , thanks
Posted on May 23, 2009
chrisreitano
  • 85 Answers
SOURCE: Cerwin Vega SUB8...how do I connect
grady66,
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
-Chris
Posted on Aug 13, 2010
SOURCE: V-35 Cerwin Vega
Turbo 37: Did you ever root cause your V35's? I just ran across this post. I own a pair and have done some amateur / professional speaker building. Let me know if you still want to repair. tro
Posted on Apr 02, 2011
I have a set of cerwin vega AT15's my dog decided to put his paw through the one surround and puntured the paper cone I need total 15" woofer replacements or repair. or I need replacements I can buy and...
Ebay sell Cerwin Vega Surround (rubber bit) replacements. If he has ripped the cone too, appart from replacing his back legs with wheels (joke!), contact Cerwin Vega directly and they will send you out a new "driver". These are easily fitted at home by any one with a screwdriver
Sep 02, 2010 | Audio Players & Recorders
Left Channel Woofer not working. I suspect the
I suspect a "blown" woofer! What does the dealer have to say?
Apr 20, 2010 | Cerwin Vega LS-10 Main / Stereo Speaker
Cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Mar 09, 2010 | Cerwin Vega Audio Players & Recorders
Need to find a cerwin vega 6 1//2 mid range woofer model number v-6f but i would like just the speaker only not the whole floor stand
muz782,
Replacement drivers for home speakers are only sold directly from Cerwin Vega. If you can find one online, it will not be authentic CV.
http://www.cerwinvega.com/contact_us.php
-Chris
Feb 11, 2010 | Cerwin Vega V-6F 6 1/2" 2-way...
Cerwin vega at60 and dc1515
Jul 08, 2008 | Cerwin Vega CLSC-15S Subwoofer
Cerwin Vega CLSC-15S Subwoofer Logo
49 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Joe Lamb
Joe Lamb
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
