Question about Breville Kitchen Appliances - Others
Hi I have a breville deep fryer a bdf 450 when i go to turn it on it comes up with an error on lcd screen
  • 77 Answers
SOURCE: DEEP FRYER WONT HEAT
have you tried taking out all of the oil and washing it realy good I know that mine wasnt working and thats what i did and it started heating up again
Posted on Feb 19, 2008
SOURCE: Rival CFZ530 Deep fryer
I had this same problem which is how I came across your post, and I found on the Rival website ( www.rivalproducts.com ) you can email the company and tell them the model number and they will email you the manual, and if you're like me and hate to wait that long, you can call their customer service number and tell them what you need and they will email you the manual in about an hour. The number the website gave me was  1-800-323-9519, and I also realized there was also a number on the box too.
Posted on Apr 16, 2008
IrishDruid
  • 2712 Answers
SOURCE: Deep fryer power cord
You can contact Rival HERE.
Mailing Address:
Rival
c/o JCS/THG, LLC
13120 Jurupa Avenue
Fontana, CA 92337
Telephone: 1-800-323-9519
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 17, 2008
SOURCE: Deep fryer not working
May Blow Your Fuse Replace the fuse
Posted on Jul 18, 2008
SOURCE: cleaning deep fryer
You can not remove the reservoir because if you clean it out with a hot soapy spange or rag. turn the frier over and remove the plate you will see why the reservoir wont come out.
Posted on Aug 05, 2008
Can i buy a handlefor halo actifry
The only place you will get this part if it is available is from Breville themselves under warranty. Click Service and support on top right.
Halo Health Fryer VDF065 Breville
Sep 23, 2016 | Breville VDF065 Halo Health Fryer
I have lost the instruction booklet. Need a replacement
http://www.breville.co.uk/downloads/dl/file/id/293/halo_fryer_vdf065_vdf084_instruction_book.pdf
Fix'dYa!
Mar 17, 2015 | Breville VDF065 Halo Health Fryer
My Breville BDF450 will not turn on (no lights no nothing). Heated oil up prior to cleaning. Cleaned and changed oil now unit will not work at all
Did you pour out the oil when it was still at it's hottest temp? I would guess there is a master overheat sensor that tripped off. It will be a little thermodisc with 2 power wires connected to it. Find and replace that thermostat sensor. You can test it for continutiy with a volt meter.
Dec 11, 2014 | Breville Deep Fryer BDF450
Manuals breville
There is a download link on this page>>>http://www.breville.co.uk/breville-halo-fryer-vdf065.html#
Breville Halo Low Fat Fryer Free Delivery
Apr 28, 2014 | Breville VDF065 Halo Health Fryer
The reset button on my Breville DF30 will not reset when pressed. So it is not able to heat up.
Hi there.
If the unit is cooled down and the button will not reset, you have to replace the reset button, its mechanical part may have worn out that's why it wont go back to its normal position.
Regards.
Jul 18, 2011 | Breville DF30 Deep Fryer
Trouble light comes on, can barely read the instruction around it(faded over time)It says to push a red button but not sure where the button is. Help!!
When trouble light comes on, it indicates that the hi-limit is tripped (this happens when oil temperature exceeds 450 Fahrenheit). The red button is located at the upper back panel of the unit, give it a push to reset but if nothing happens after resetting the button, the hi-limit needs to be replaced. Also try to check if the thermostat is working, stuck thermostat's mechanical contact will cause the hi-limit to trip.
May 05, 2011 | Wells F14 Deep Fryer
Hello, my Breville deep fryer has suddenly powered off because I moved it. What is the matter, please?
Some deep fryers have a magnetic quick release on the power cord. First, check to see if the power cord is securely fastened at the wall and at the base of the fryer.
Safety features of deep fryers include auto shut-off when oil overflows or reaches a certain vertical point in the fryer, or if there is too much or not enough oil. Drain the entire fryer and slowly refill it to the maximum fill line.
Some outlets, especially in bathroom and kitchen areas, have GFI (Ground Fault Interrupt) circuits which detect overload or short situations and shut off. You can see an example here. Ensure the "reset" button is pressed down. Another cause could be a tripped circuit breaker. Check the circuit breakers to ensure all of them are in the "on" position.
Mar 09, 2011 | Breville Kitchen Appliances - Others
Breville bdf deep fryer keeps tripping out /turning off have to push reset buttons to get it started again after having to wait 10 mins to reset
That sounds like either a faulty thermal trip, or a faulty overheating fryer.
Is it clean around the element because if not the heat will build up, much like the fur on a kettle and cause the element to overheat.
Hope this helps.
Jan 02, 2011 | Microwave Ovens
Kitchen Appliances - Others Logo
117 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
