Question about RTO PasLode 900420 Impulse Framing Nailer
Quit firing nails motor comes on but nothing happens when pulling trigger
  • 760 Answers
I am assuming that you have changed the gas cylinder. Make sure you have the exact correct cylinder, because there are some that look like they fit, but don't quite seal. This unit requires battery charged for ignition and induction fan. And it requires fuel to drive the nail,.
Posted on Oct 16, 2010
Have stinger cn100 nail gun, stopped plunging nails in wood, when pulling trigger, nothing happens?
There is a roll pin that holds the trigger in place. Remove the roll pin with a punch or a nail filed flat. The trigger valve will then come out. Clean, lubricate and reinstall. It should work.
Dec 16, 2017 | Air Tools & Compressors
With 90 # air and PC nails. When I pull the trigger nothing happens. No air noise, no nailing, no movement - just dead. It's been oiled every use.
Most likely stuck trigger valve. Easy to check. Remove nails, remove trigger to expose the firing pin of trigger valve. Connect air and very quickly depress the firing pin all the way in. If the gun fires , adjust the safety to depress the trigger valve completely. If the gun does not fire, replace firing valve, or remove and check /lube o-rings in valve. Good luck
Jul 11, 2015 | Air Tools & Compressors
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
My framing nailer shoots out 2 nails at a time
Assuming that you are using the correct nails. This will usually happen if you have bump-fire trigger and are trying to place the gun on the work then pull trigger. Replace the safety spring if weak and bump-fire only (spring should be very firm). If you have single fire trigger, replace the trigger and the trigger valve for good operation. If you have always been bump-firing and now double firing, replace the safety spring and trigger orings. Good luck
Oct 21, 2012 | Air Tools & Compressors
Gun is full of nails, but acts like it is empty (the plunger won't advance). You go to tap it with the trigger pulled, and it just does nothing. Seems like firing pin is not getting air or somet
If no air is leaking from the gun, take out the nails, remove trigger by removing 3mm hex head bolt to expose the trigger pin. With air connected and side door open so that you can see the feeder, quickly depress the trigger pin with finger. Gun should fire. If gun does not fire (only makes air sound at trigger) dissconnect airline, remove head and lube headvalve with white grease and reinstall. Test again. If ok replace trigger. If still no joy, replace trigger valve with new factory or generic (part # TVA6). If gun fires but does not activate the feeder claw, remove two 6mm hex bolts from front of gun and split apart upper and lower body and check white oring (part # 149885) Good luck
Oct 16, 2012 | Stanley Bostitch Rn461 Gun Coil Roofing...
I have a Max cn70 nail gun. When trying to fire the gun, air seeps from the trigger assembly and will not fire. Help!
Hello, sounds like a nail is jammed in the chamber. Happens frequently. What you do first is disconnect the gun and empty any nails. Then, with a screwdriver or a big nail hit the ram driver back down . Reconnect and test by depressing safety latch and pulling trigger. Repeat. Hope this helps. -ROB
Feb 10, 2011 | Air Tools & Compressors
When I pull the trigger it will not fire a nail, air running through the nailer is all that will happen?
You could have a nail jammed. Remove the front assem. where the nails come out and see if somthings stuck like a nail.
Jan 23, 2011 | Dewalt Clipped Head Framing Nailer
Nail Gun Problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Nail Guns Safety problem
Aug 27, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
RTO PasLode 900420 Impulse Framing Nailer  Logo
229 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
