Question about Dell 5650 Computer Speakers
Audio is not working - Dell 5650 Computer Speakers
  • Dell Master
  • 32,281 Answers
Try re-installing the audio driver.
Normal 0
You can download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
http://welcome.hp.com/country/au/en/cs/support.html
Posted on Oct 16, 2010
Windows XP SP3 platform with single Delta 66. Record audio works fine but I'm unable to hear played back audio through computer. It appears onboard audio card disabled. Any suggestions?
Go to Device Manager and enable the audio card.
If you cannot enable the audio card or it is not working then install the audio driver again.
Mar 30, 2010 | M-Audio Delta 66 Sound Card
My audio is not working
You can check your audio by using these steps.
1. If you have speakers, check if it is plugged properly into your audio port which is the port with the "green" color. Check your speakers if it is turned on, put to low volume, or no power or check your audio settings on your computer if it is muted.
2. If step 1 doesnt make your audio work, you should check if your computer has audio driver installed, it depends on the manufacturer which audio driver should you install. if it is built in audio, you could use the mother board driver cd.
3. If still your audio is not working , you may have problems on your device. If you have external audio device, you should try to check if it is plugged properly on your motherboard. If still doesnt work. you should buy a new one..
Hope this will help you out. =)
Jan 02, 2010 | Computers & Internet
Audio Problem
when was the last time when your audio was working fine? try to do a system restore first, if not fix then download the latest audio driver. uninstall then reinstall the audio driver. try connecting an ext speakers if you will audio if yes then check audio settings from the control panel. if not then update the bios if not then replace motherboard.
Oct 15, 2009 | Dell Inspiron 1525 Notebook
Problem audio
hi im josh in phils. friend may i help you?
Audio is not working. Friend i guess you already know that to make the pc audio work is you need to install or run the audio driver separate cd if you are using with audio cards.and mainboard driver if you are using audio built in on board. then if you haven;t did it so you need to do it.but if you have already installed a such then it is still not working then here are some suggestions of what to do.
1. Go to audio setup utility in BIOS and have the audio select enabled.if done
2. try to run the cd audio first while installing some software right after formating or installing O.S. because there are some mainboards that requires the audio to be run first before the others and you failed to do that audio will not work.
3.There are mainboards or pc such as IBM netvista IBM, COMPAQ, other branded etc.and especially your DELL. that even though you have installed the software it will not work automatically you need to run it first manually to work here: you go to the my computer ryt clck thenn device settings then update/install driver clck then browse go to the drive c where the software audio driver installed find the run or setup then hit it let it run for a while then after press ok reboot your pc. then at start of wndows you wl hear a sound it means successfull installed you can now play audio progrms. thats all friend base from my experience of such many units. good luck hope i helped you.
Mar 07, 2009 | Dell Inspiron 1501 Notebook
Audio doesn't work on some apps
u just re install audio driver, sometimes system took defautlt driver .
Aug 05, 2008 | Computers & Internet
Audio not working and bought the computer with sound
Audio not working means there must be a driver problem.Try to install the audio driver again.If it is high Definition audio driver first uninstall audio driver and high definition audio driver package.Reinstall the driver again.if problem persists check for the audio port.
Jul 05, 2008 | Acer Aspire™ T180 PC Desktop
Delta1010 on Hacintosh
WORKING DRIVER HERE FOR M-audio PCI:
 M-Audio Delta 44 (verified)
 M-Audio Delta 66 (verified)
 M-Audio Delta 410 (verified)
 M-Audio Delta 2496 (verified)
 M-Audio Delta 1010 (works for some)
 M-Audio Delta 1010LT (verified)
 Terratec Phase 88 / EWS88MT / TS88PCI (tested only on EWS88MT)
 Terratec EWX2496
I tested on my M-audio Delta 1010 with box today and everything incl. SPDIF is working great on my osx86 v_7 10.5.8 system! The only thing not working is midi as told on website. Im submitting file for the above sound cards! Dont Forget to donate some money to this guy!!!
http://www.audio-evolution.com/drivers/
http://www.insanelymac.com/forum/lofiversi...t25145-150.html
Mar 22, 2008 | M-Audio Delta 1010 Sound Card
Dell 5650 Computer Speakers Logo
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
