Hello there, My 7.5kg front loader whirlpool wfs1071bd is leaking out of the powder despencer while it is filling up. Generally the water that leaks out is hot. Have you come accross this problem before? How would i fix this problem? Many thanks,
SOURCE: Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
Posted on May 09, 2008
  • 43 Answers
SOURCE: Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Posted on Nov 10, 2008
ginko
  • 19396 Answers
SOURCE: Whirlpool front loader WF665/1 spilling water during cycle
that means that the water is leaking from the hows at the back of the detergent drawer.
This is not a difficult fix, however the washing machine must be taken apart to access the detergent hose and find the leak.
Always better to call a technician.
Posted on Nov 16, 2008
  • 1028 Answers
SOURCE: My whirlpool front loader washing
if you are using dry detergent remove dispenser drawer and clean also ck for undussolved detergent inside dispenser tube into washer both ends
futureloginn
  • 734 Answers
SOURCE: Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
We have a Whirlpool WFS1071BD. We are on tank water (rain water), with resultant poor pressure. We're finding our washing is increasingly smelly (mould?). Is there anything we can do/put through to make it...
epsom salts are the only thing that makes a difference tried all the new gear doesnt work as good as epsom salts every two weeks 1/2 cup on hot wash with no clothes & use cold power advanced washing powder this is the best way of keeping control of it once you get it clean you have to keep on top of it the smell doesnt take long to come back with out continues treatment.
Jan 10, 2011 | Whirlpool Washing Machines
Water leak from front powder/conditioner drawer.
Completely remove the dispenser unit. look inside the recess you have just taken the dispenser drawer from and look up. You will find this is covered in muck. Clean it with an old toothbrush or something but do not use too mush pressure. This should solve your problem. If not then you will need to replace the dispenser unit completely
May 22, 2010 | Whirlpool AWM5125/1 Front Load Washer
Leaking water
Water can't leak out the top from overloading unless the entire tub is full of water which is a major malfunction, or an inlet hose between the powder drawer and tub is somehow blocked (extremely unlikely).. Are you using topload detergent? Normal detergent can foam up and out through the drawer and leak onto the floor..
Normally water enters through the top of the powder tray to disperse it into the tub. pull out the tray slightly while filling to see how this works. You might be able to identify that the water is not flowing properly. Normally you can really pack into a front loader, I've been thrilled with my 5100 for 8yrs.
If this doesn't help let me know and I'll suggest next step.
May 14, 2010 | Whirlpool AWM5125/1 Front Load Washer
Bad bosch
The grey sludge may be due to incorrect soap powder (use only front loader) or excessive powder use. Minimise the powder use and insure you do a very hot wash once every 4 weeks to break down powder that may be building up.
Regards Sam
Apr 15, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Whilpool front end loader leaks water after done filling
theres a hole in gasket (bellows),,,,now also check your detergent draw if water pressure is to high it will splash over and come down inside of cabnit...
Dec 24, 2008 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool front loader WF665/1 spilling water during cycle. Water is leaking from where the powder is deposited into the machine during the filling stage of the washing cycle. The machine will continue its...
Nov 16, 2008 | LG WM2487H Front Load Washer
Leaking Water
Nov 10, 2008 | Samsung WF337AA Front Load Washer
Whirlpool washing machine Model AWM 5104/5
the despencer has a motor on it are a water valve that puts the water into the right despencer at the right time to make it work look under the top if its a water valve type needs new valve
Feb 25, 2008 | Whirlpool AWM5104/1 Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
