Question about Samsung DV337 Electric Dryer
Hello my samsung dv377 dryer is not heating in any mode.
    President:
  • 3,074 Answers
This is the best and easiest, Hope it helped Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Posted on Oct 16, 2010
  • 22 Answers
Probably the electric element is open , (no curcuit) and or a thermostat is faulty or the high limit is open
Samsung dryer in cool down mode in all settings
Check all heating components. If they all check out good, then most likely a control problem
Nov 15, 2017 | Samsung Dryers
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
May 02, 2017 | Samsung Dryers
My dryer is not heating up
You can view a short video as to how they work and order parts here; http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8---/Dryer-doesn-t-heat
Good Luck!
Rich Lilja
Sep 23, 2014 | Samsung Dryers
My one year old samsung dryer runs but does not heat - air flow is good. Any ideas
Hello- The usual cause is a bad thermal fuse or heating element. Unfortunately you will need to have a Tech out to look at it, these aren't that easy to take apart and check. Good luck, best regards.
Sep 27, 2010 | Samsung DV218AEW Electric Dryer
The dryer is just over a year old and runs normal but does not heat up. there is lots of air blowing out of the vent and it is set in heating mode.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 16, 2010 | Samsung DV448AEE Electric Dryer
2 yr old samsung dryer does not dry clothes totally
Remove the vent completely and clean it out 100 percent. Elbows (corner bends) will hold more than you think causing the dryer to keep the heat off. The sensors for the newer style dryers detect plugged up vents and shut down the heating modes. If cleaned and still no heat the spark ignitor has gone bad
Apr 07, 2010 | Samsung DV218AG Gas Dryer
Hello, I have a 3 yr old Samsung dryer that does
YOU MAY WANT TO CHECK THE MOISTURE SENSOR THIS WAS WHAT WAS WRONG WITH MINE THE GLOW ROD WOULD HEAT UP BUT NO GAS TO LIGHT
Jan 19, 2010 | Samsung Dryers
Samsung DV337 Electric Dryer Logo
1,217 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
