Question about Miele Dishwashers
Miele dishwasher - what is F11 - Miele Dishwashers
4 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Got a Miele G2220sci dishwasher
F19 is water in the cabinet takes too long to heat up. you can reset the heater limiter..
Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. If the fault message reappears
take off service panel press button on the heater limiter red-brown located on the left side of the plinth...
hope it helps
Posted on Sep 07, 2008
  • 30 Answers
SOURCE: Miele Optima dishwasher. Doesn't drain,
check the drain solenoid valve if working properly or check if voltage is present if you press the drain switch.
Posted on Aug 12, 2010
  • 251 Answers
SOURCE: miele dishwasher drain blocked. f11
Hey there - if you have not read any of the post on here - the pump could be serviced from inside the machine, empty trays out, revoe the steel mesh on bottom with a lock lever where the drains is, under here you will see a steel spring like clip, move & pull the housing under it, then the pump impellar is there - just clean it out carefully - assemble or close door run a drain for 2-3 secs, assemble . should be good to go.,
Posted on Jun 17, 2011
Miele dishwasher drain blocked. f11 message. Help!!
May 25, 2011 | Miele 24 in. G665 Built-in Dishwasher
F11 appears on the display ?? what can that be from.??
water outlet is restricted,water remains in the cabinet at the end of the cycle page 46 of your manual tells how to fix this error by reading under the care and cleaning section of your machine http://www.miele.co.uk/products/manuals/dishwashers/G1220_1230_2220.pdf note this is an older model then yours but the error codes have not changed nor has the cleaning part if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation it allows me to help others in similar situations Thanks Rick
Mar 15, 2011 | Miele G2470SCSFSS Dishwasher
Miele Optima dishwasher. Doesn't drain, and display says "F11"
Aug 12, 2010 | Miele Dishwashers
Dishwasher not draining
you need to remove the drain pump motor and see what is obstructing the impellar.(small shreds of glass:small popcorn pieces etc. Doesnt take much to stop the drain pump.Try and get to drain pump from the front. Miele very compact.
May 28, 2010 | Miele Incognito G818SCVi Built-in...
WHAT IS F11 ERROR MIELE DISHASHER G 1232 SC
hi
this is a drain fault. you will probably find the drain spigot under the sink is blocked where the drain hose connects.
Dec 13, 2009 | Miele G892SC SS Dishwasher
Fault 11 - inlet or outlet blockage
THIS TYPE OF M/C PERMIT WATER TO FILL IN LONG TIME IF THE PRESSUR IS LOW
I THINK AFTER ABOUT 3 MINUIT YOU CAN OPEN THE DOOR AND CHECK OF LEVEL OF WATER TO ASSURE IS LEVEL OF WATER IS SUFFISUNT OR NOT
Jun 14, 2009 | Miele Incognito G658 SCVi Built-in...
F11 error
I found a piece of wood inside the door latch mechanism and removed it. The F11 error has not appeared since.
Aug 08, 2008 | Miele Dishwashers
CODE F11 ON MIELE 1220 SCH
I disconnected the drain where it enters the S bend from the sink. I found the nozzle into the S bend was blocked. I probed this with a screwdriver and cleared the blockage then I reconnected the drain. I turned on the dishwasher again and the F11 code was cleared. The dishwasher operated ok again.
May 14, 2008 | Dishwashers
Dishwashers Logo
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
