Question about Royal 10X Shredder
Is it possible to unjam this shredder. It was allowed to get too full and I started eating it's own shredding . I have pulled all of the paper out that I can - but it still won't go.
    Genius:
  • 1,218 Answers
If you have cleared all jammed paper out of the unit but its dead and wont run then its likely you have blown the PCB inside...replacement parts you can get from Royal at 1-800-524-0799.
Posted on Oct 20, 2010
  • Anonymous Oct 20, 2010
    It can be opened if necessay...open the waste bin..remove 4 screws inside underneath that hold the cutting head onto the cabinet. Then remove about 6 screws from the bottom of the cutting head so that the top cover can be removed...If its dead and you need parts contact Royal at 1-800-524-0799.
We have a fellowes shredder. It got full and jammed. After cleaning and emptying it will not turn on. Is there a reset button? Thanks. Betn
We've found that when the container is overfilled with shredded paper, it will begin pulling shredded paper back into the cutters and jamming the machine. Sometimes reversing the machine will spit the paper back up, but if it is thoroughly jammed, only way to unjam it is to UNPLUG it first, then manually remove the paper from the cutters. Then, be sure to dump the container BEFORE it is filled with paper.
Jan 12, 2017 | Fellowes Office Equipment & Supplies
My Executive Machines EPS 1200X shredder works in reverse, but does not shred.
there should be a forward/ reverse switch that is used to unjam paper being shredded. check that
if it is automatic then check for paper stuck in the shredder causing the reverse action.
May 12, 2015 | Shredder Office Equipment & Supplies
HOW DO I UNJAM SB 99C SHEDDER
Try spraying some WD40 into the cutting blades then turn it on to forward it may unjam itself.
Aug 25, 2014 | Fellowes SB-99Ci Shredder
How do you remove the top to see the gears in a Royal 16CDX cross cut paper shredder. The overload message is displayed, and I don't know how to get it unjammed.
a possible solution is to UNPLUG the unit, reach in from underneath and start pulling stuck paper out. On mine (different model) I can remover the paper receptacle bin and reach up to remove stuck paper. this usually is caused by overloaded bin pushing shredded paper back up to cutters because it is overfull......BE SURE TO UNPLUG FIRST !!!!!
Nov 17, 2012 | Royal 160MX Also called 16CDX Cross-Cut...
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Don't know how to open the basket
If the basket does not slide easily out of the shredder cabinet it maybe "jammed full" of shredded paper which is preventing the basket from sliding out. There is a clear concave "handle" on the front of the basket which users should reference to determine the fullness of the basket. I pulled out and pressed upward on the "handle" it easily popped in towards the basket. From there it was possible to remove enough of the shredded paper to allow the basket to slide out. WARNING: UNPLUG THE MACHINE AND REMOVE THE PUPPY FROM THE ROOM.
Dec 12, 2010 | Royal PX1000MX Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
My shredder is jamed.
Take the shredder off of its bin, turn upside down, make sure it is unplugged, and pull any pieces of shredded paper out of the shredder teeth, If the reverse mode did not unjam it then you might try opening it, by the inside of the shredder, and unjamming it that way, may I add that there is a sticker covering one of the screw holes that will say "if removed warranty is not good anymore".
Aug 11, 2010 | Aurora Electronics AS662C Shredder
My shredder is jammed and I cnnot get unjammed
Hi. Go to the local hardware store and purchase a small pair of needle nosed pliers. Use these to pull the paper from the shredder a little at a time. Then in the future only shred up to 3 sheets at a time so it does not jam on u. J.
Aug 06, 2010 | Royal 160MX Shredder
Something is jammed
I was able to unjam an ATIVA DX 180 D shredder now the shredding blades won't turn but the motor is running.
Jan 08, 2008 | Office Equipment & Supplies
Royal 10X Shredder Logo
258 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
