Question about Maytag MAV7600 Top Load Washer
Maytag Atlantis mav 7600 aww is leaking water from underneath. Does not appear to be from drain hose at sewer or pump outlet. But I cannot get machine to turn on now because when I plug in it makes the outlet reset go off.
  • 7 Answers
SOURCE: Washer make a loud squeak when the spinning stops
its the brake, just as long as it stops, dont worry about it, made a web page that has pics on how to replace the spin bearing on the maytag atlantis washer, after searching the net on how to, finding the manual, not explanatory, i decided to make this a simple 1 page web site, with lots of pictures, i hope this can help someone else in doing this job. since it would cost too much money for a repairman to do the job, better to buy a new one instead, i tackled the job. since it basically takes apart the whole machine, it might help others even if they dont have the spin bearing problem but other parts to replace,
http://www.geocities.com/maytagrepairwasher/
Posted on Apr 07, 2008
huuum
  • 750 Answers
SOURCE: maytag atlantis washer mav-31
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
Is t your washer cleaning the clothes and operating fine other than the noise?
If so do not spend any money on it unless it breaks or does not operate!
"If its not broken do not fix it!"
I know this is not the what you wan to hear!
I have a telephone number of the consumer affairs of for maytag that's hard to find!
If you call them thay will demand that thier servicers find and remedy the problem or swap it out for you!.
Even if it is past warranty.
I'm not at work for another couple of hours.
When I get there I'll give you the 800 number for Whirlpool (They now own Maytag) Consumer affairs and you can cal Monday!
I do this frequently for my customers!
Everyone knows,
"It's easyier to keep the customers you have than find new ones"
But no matter what happens,you have no need to pay the repair persons child's college tuition!
You have your own needs!.
How much did you spend on this machine even though it did wash and perform?
Noise is not broken or failure.
I had a Maytag Neptune that did this for 6 years and I fixed 2 other problem unrelated .
Then on the third break down I dumped it in the trash and bought myself a Speed Queen Commercial
washer that will last me 25 years for half the price of the $999.00 Maytag Neptune.
When I complained to my father about the noises in our family car he used to tell me,
turn on the radio.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 28, 2008
canbruce75
  • 1776 Answers
SOURCE: Maytag Atlantis 7700 AWW - no cold water wash or
Look for a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are clean of rust or debris. The solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Posted on Aug 19, 2009
aasc
  • 1606 Answers
SOURCE: shreiking spin in rinse cycle
Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
Posted on Oct 11, 2009
Testimonial: "Thought it might be a belt rather than the pump."
heatman101
  • 43501 Answers
SOURCE: Maytag Atlantis MAV-14
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 05, 2010
How do you replace the seal so it stops leaking water?
Being a top loader it is to be confirmed if the leak is from the seal which is in the top section Normally the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
http://www.espares.co.uk/advice/washing-machines/a/7
Sep 15, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
It wont cycle thru anything
There could be several reasons for washer not to fill .Fill washer with water and wait for the timer to get to the drain mode.Unplug the washer from the electric outlet.Open the case, and disconnect the water hose from the outlet of the water pump.If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.Reassemble hose from step 3.Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
Thanks for contacting Fixya.com
Nov 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Shreiking spin in rinse cycle
Oct 11, 2009 | Maytag Atlantis MAV6000 Top Load Washer
MAV Atlantis 6000
hi. thanks for the question .the clicking sound is something caught, in water pump. the rubber smell is the belt . pull washer away from the wall. small door at the back left corner ,remove pump on the floor. remove 3 3/8 bolts remove. replace . belt underneath washer . replace thanks the appliance doc please rate me
Aug 17, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer Model MAV6000
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine, parts are not that expensive, 50-80for bearing kit, here is my site on how to do it
there is also a download for the repair manual
http://maytagwasherrepair.googlepages.com/index.html
Jan 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Loud noise during spin cycle
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV7600 Top Load Washer Logo
278 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
