Question about Kitchen Ranges
Water Softener Flint Walling Star Model: S07DC32DR Do it Best SKU: 433179
2 Suggested Answers
  • 119 Answers
SOURCE: my flint and walling sump pump went out, is there
u should go online to the manufactures web site and look.
Posted on Apr 19, 2010
Why is water sitting in the tank and how do we get it to drain so we can add salt?
the salt water is what removes the calcium and lime from the other tank containing the compound zeolite that does the actual softning of the water the salt tank should have water in it drain some out pour in salt
Oct 10, 2014 | Northstar North Star Water Softener , Flow...
Asotoria model aep12n - do I have to use a water softener?
You can use it without one but it would be best to install a water softener system like an everpure ql3 head with a 7S0 softener. That might run you about $200 installed.
Mar 31, 2014 | Astoria Argenta Coffee Makers & Espresso...
Fabric softener compartment is filling up with water.
the hose need to be clean there is something that let the water get stuck there check inside if you see what is cluge in the unit or the internal hose, try to clean it with warm water
May 23, 2010 | GE Energy Star WCVH6260F Front Load Washer
My flint and walling sump pump went out, is there a universal replacement switch?
Apr 11, 2010 | Plumbing
GE Washer Model WCVH6260HWW, Fabric Softener Won't Dispense/Drain
I took the tray out and placed it to the side. Then I ran a common pipe cleaner through the nozzle that supplies a water spray to the tray. So far, so good.
Jan 28, 2010 | GE Energy Star WCVH6260F Front Load Washer
I NEED A SERVICE MANUAL FOR MY CULLIGAN WATER SOFTENER. MODEL# 01014556 SERIAL# 2903H0010
Your best course of action is to contact Culligan here:
http://www.culligan-store.com/contact.asp
Nov 15, 2009 | Culligan Sediment Water Filter
Was turned off and now water does not come on
So long as the motor is still good. The usual problem is rust build up in the housing/impeller assy.
Sep 17, 2009 | Star Manufacturing Flint Walling/Star...
I have a shallow well F and W well pump,three quarter HP. It makes more noise now than when new. I have to lower the high pressure setting to get the pump to shut off, it seems a little slow about building...
Yes, you should have a pre filter in the form of a "y" strainer before the pump check to be sure this is clear first. If you do not have one or something along those lines you need to install one and check it at regular intervils. After that You can with the power off at the breaker open the pump and check the center of the impeller for clogs if this does not fix the problem you will need to remove the impeller and check the water vanes in the impeller. This get's a little deeper and may be something you want leave to a pro, but try the other things first. Good luck.
Aug 07, 2009 | Flint & Walling/Star Water # 1/2HP Shall...
Kitchen Ranges Logo
118 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
