My front load Samsung is giving me an E3 error code
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 120 Answers
May be you would have overloaded it! try washing the clothes in cycle..like split you cloth load and wash,rinse!
Posted on Oct 17, 2010
My Samsung washing machine, front load, showing E3 error, can you help? Thank you
Samsung Washing Machine Error Code 3E = Motor Drive Error or Hall Sensor ErrorWhen your Samsung Washing Machine shows the error code 3e, the most common reason is because of a "wire harness or wiring connection is loose, not connected, or wiring is damaged". Checking the wire harnesses on the motor, hall sensor, stator, control board etc, will usually result in finding a faulty wiring connection or bad wire hareness. Reconnecting or replacing the wire harness or wiring will fix the washer and clear the 3E error. See more troubleshooting info below...
how to fix error code 3e on samsung washing machine Google Search
Mar 23, 2018 | Samsung Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Samsung front load washer. What is causing E3 code?
My error code database says:
Error: E3,
Machine: Washing Machine,
Type: Samsung,
Fault: Too much water in machine. Check pressure chamber for blockage,check pressure switch and air hose for leaks, check solenoid for sticking or jammed valve.
Dec 26, 2015 | Washing Machines
My dishwasher gives an E3 error
The E3 error code is not a defined error for this dishwasher. If you are sure it is E3 then best option is to give the controller a reset. This is done by
Press the Delay Start + Normal + Power keys at the same time for two seconds to enter Service Inspection Mode.
- "ALL" is displayed for the first three (3) seconds and then "t1" is displayed.
Press OFF at this stage. Do not attempt to run the inspection as this could damage the dishwasher unless you are familiar with the what each mode does.
If the Error E3 keeps coming back then call the Samsung technician.
Apr 15, 2014 | Samsung DMR57LF Builtin Dishwasher
After main washing, stops and can't spin. Gives error E3.
The "E3" error indicates that a Samsung washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
Sep 25, 2013 | Washing Machines
Errhr code ee
There is no error code ee
Could it be 3E or E3
if is 3E then it means "High current detected"
if its E3 then it means "Motor not running properly"
here is the link to the manual I checked all manuals starting with the model number Wf337AA the error codes are all the same.
http://downloadcenter.samsung.com/content/UM/200710/20071010083409359_WF337A-02440A-06[1].pdf
Jul 11, 2012 | Samsung WF337AA Front Load Washer
Error code E3 on Samsung Frontier
this mean motor not running properly.
You have two options: repair yourself or call some service tech.
God bless you
Jul 02, 2012 | Samsung WF337AA Front Load Washer
We get an e3 error message and we have no idea what that means. The machine will start but then at some point it simply stops. we have been able to use the rinse and spin cycles to get the water out of the...
It's an over load error. Don't put alot of laundry in the drum.
Copy and Paste from the service manual
- Motor overloaded due to too much laundry (Nonsensing)
- The motor hall sensor terminal is not connected.
- PBA fault
- The motor driving error from the PBA is weak.
: Unstable relay operation, etc.
This error
occurs when an
interference is
generated due
to too much
laundry, etc.
Dec 28, 2009 | Samsung WF337AA Front Load Washer
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
