Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52525 Projection Tv
A frind gave me this Tv and said it needed a format board what is this and where do I get one.
  • clanham Jun 08, 2008
    When I plug it in and push the power button it does not come on the timer light just blinks. I also reset it, and the timer light starts blinking again.
    Problem Solver:
  • 16 Answers
There are a series of capacitors that go bad in these tvs.
1. tv won't come on after changing lamp.
a. 2) 1000mf/10 volt capacitors on power supply board.
2. green power led constantly blinks
a. 4) 1000 mf/ 16 volt capacitors leaky. change to 680mf/16 volt on DM board.
Also the 4 1000mf/16volt caps on formatter board can become leaky(bad)
Posted on Jun 11, 2008
  • coffeedrunk Jun 12, 2008
    revision too my 1st solution.
    the power supply capacitors are 3300mf/ 10 volt
?? give description of problem?? plug it in and hookup some cable!
Posted on Jun 03, 2008
Mitsubishi WD-52525 52" Rear Projection HDTV popped, bad picture and vibrates
The pop was a high voltage arc of electricity that blew some vital components on the main circuit board. The unit is of no use now. Repairs are far more than replacing the TV.
Feb 27, 2014 | Mitsubishi WD-52525 52" Rear Projection...
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Timer light blinking on my WD 52525 tv will not turn on
main board or bulb went out it is a diagnostic indicator used on the timer display to let you know its not working.
Mar 27, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Tv stays on for about 3 minutes the shuts off
If it is Mitsubishi WD-52525 DLP TV then it sounds weak lamp problem in TV and TV needs lamp replacement.
How old is this TV and did you replaced lamp recently?
Lamp replacement is written in user manual of TV and it is easy work.
Please buy Mitsubishi original lamp for TV safety.
Thanks.
Oct 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My Mitsubishi WD-52525 is only showing black and white rectangles on the screen. I hear sound, but there is no picture.
Check the white rectangular ceramic fuses on the FMT board. You blew one of them so there's power missing to some of the circuitry.
Jun 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 picture problem
you didnt mention which two boards you replaced the caps on however each board in the chassis has the same capacitor issue. Sounds like you need either of the four V26 Repair kits. The FMT repair kit, The signal Repair kit, The Terminal 1 or the terminal 2 repair kit
Jun 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green timer light on mitsubishi wd 52525
disconnect the connector for the front switch control board. Try turning it on with the remote. If it works replace that board, also look for bad caps on the small signal board. they're 1000Mf 16v
Mar 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP WD-52525
first unplug and let it sit for a couple of hours and then try again.
Jan 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
112 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
