Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Maytag Quiet Servies 100
I now suspect a clogged spray arm. Sometimes I see cantaloupe seeds stuck in the holes, and I poke them back in. Is the spray arm removable and cleanable by an amateur or do I need a pro?
Bill of Carmel
  • Bill Carmel Jun 04, 2008
    I will give it a try. Something definitely needs to be done. Thanks.
  • 868 Answers
Yes remove the arm ,if its the lower arm it un screws,the upper arm snaps on& off.
Posted on Jun 03, 2008
  • Archie Ferrarini
    Archie Ferrarini Jun 06, 2008
    iM HERE TO HELP
  • Archie Ferrarini
    Archie Ferrarini Jun 07, 2008
    Helpful is the same as repaired in my eyes!!!
My Miele dishwasher is about 16 months old. Initially it was awesome. Now it doesn't get anything truly clean on any rack. Every item has scum and traces of food or drink left on it. I've cleaned the...
Hi bjw.... clean the dishwasher by putting 2 cups of vinegar into an empty dishwasher and running the longest and hottest cycle.
Repeat this washing as needed but generally at least once a month. Joe
Thanks for choosing Fixya!
Feb 27, 2011 | Miele G880 Dishwasher
I have maytag jet clean quiet plus II model mbd6000aww. The jets are not spinning and the water is not spraying. I was hoping to get some DIY assistance. Thank you. Jennifer
The most common thing I've seen causing this is when the holes in the spray arms ore clogged. Take the spray arms off and check the holes carefully for debris and clean out whatever you find.
Feb 14, 2011 | Maytag Dishwashers
Upper rack spray is clogged
it has a pressure insertion fitting that snaps into the arm thru the hole,you need to press in on the ears on the bottom of the are to release the plastic grips to let it drop out,then the arm should remove after this
Apr 19, 2010 | Maytag MDB5100A Dishwasher
My Maytag Qriet Series 100 Dishwasher won't drain
Check the drain hose connection at the sink drain for local blockage. If ok, you may have to tear down the lower spray arm assembly down to the deck (noting orientation and position as you remove parts). Look for clogged screens and clogged openings in the deck. You can use a vacuum hooked to 'blow' to make sure these openings are clear. Wash the screens in hot water, detergent, and white vinegar to remove water and food deposits. Make sure upper and lower spray arms have open spray holes and no split seams. Hope this gets you running again!
Feb 10, 2010 | Dishwashers
My top rack is not getting clean, it appears spray arm is not dispersing water, can it get clogged?
Yes it can get plugged. Any debris pumped up to the arm can get lodged into the tiny holes. Also, sometimes the arm itself becomes split along the joint between the lower and upper half. Remove the arm to inspect, clean, and repair/replace the arm if split. I fixed our Maytag spray arm when it split, by drilling a series of small holes along the split parts and sewing the thing back together with fairly fine copper wire. Still working great after a number of years. The small spray holes can be poked clean with a heavy needle and the arm vacuumed out. If after all this it still won't spray properly, the intake screen at the bottom of the lower spray arm tower may need to be cleaned as well. Remove components starting with the spray arm and work your way down, noting placement and orientation of each piece. Remove the screen, and soak it in hot water, detergent and white vinegar for an hour or so. Check all holes in the deck for any food plugging. Reassemble in reverse order and check the lower spray arm for plugging as well. Hope some of this helps!
Jan 08, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The diswasher arm does not rotate or spray water
Check the small holes on the spray arm. They are most likely plugged. (candy wrappers, tooth picks, popcorn or watermelon seeds, you name it.) Sometimes you can clear the holes out, other times it is just as easy (and not very expensive) to replace the spray arm(s). List your model number if you need part numbers or instructions on removing spray arm.
May 14, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
I suspect that water is not coming out of the spray arms.  Dishes are not coming out clean.  In addition, soap dispenser is not getting rid of all of the soap.
Check to make sure the water is getting hot and that the heater in the dishwasher is working. Check spray arms for clogged holes and debris.
Feb 23, 2009 | Maytag Dishwashers
make sure your getting at least 120 degrees in water.Check the heater element,rinse aid ,clogged up spray arms.These are the most common and need to be 100% ok.
Jun 02, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Maytag Jetclean Super Quite Plus II Dishwasher
open the door when working and check the spray arms are rotating. if not, the jets in the spray arms may be blocked. very fiddly to clear but doable
Apr 07, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
117 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
