Question about Dishwashers
The lock button is on and I can't get it to turn off. I have done as directed inside the door and held the button for 4 seconds but it stays on. What am I doing wrong???
    Genius:
  • 1,075 Answers
Dont panic,?switch the machine of.let it stay of for 5 mins,restart and push and hold the start/stop button with one other button for about 30 secs,if this fails then try stop/start button alone should reset,if this fails then main door switch needs replaced.adrian,,,,
Posted on Oct 16, 2010
How do set the lock remote for a 2001 Honda civic
Try this:
KEYLESS ENTRY PROGRAMMING
Have all remotes for the vehicle on hand.
Make sure all the doors and rear hatch/trunk are closed during programming.
Only need to use 1 remote to get into program mode but all remotes must be programmed during the same session.
Each step must be completed within 5 seconds.
1. Sit in the car with all doors/trunk tightly closed
2. Turn the key to the ON position, marked by "II" on the ignition bezel so the dash lights come on, then within 5 seconds press the "Lock" button on the remote for 1 second or so and release the button.
3. Turn the key to the OFF position, marked by "I" on the ignition bezel - dash lights go off.
4. Repeat steps 2 & 3 three more times (A total of 4 times) - each step must be done within 5 seconds of the previous step.
5. Upon the 4th turning of the key to "ON", press the lock button on one remote, the locks will make a cycling sound (clunk), locks will NOT lock or unlock at this point, they will just make a noise. The system is now in programming mode. Do not turn key off.
6. Within 5 seconds of entering programming mode and within 5 seconds of each other, press the lock button ON EACH remote you are programming, for a second or so and release. This step needs to be completed within 10 seconds. Each time a remote button is pushed, the locks should cycle. Up to 3 remotes can be programmed.7. Turn ignition completely off and remove the key. Step out of car and close door. The remotes should be programmed and should work. If you have a trunk/hatch release, the button for this feature needs to be held for a few seconds before the trunk/hatch will "pop".
Mar 12, 2013 | Cars & Trucks
Hello I have a Mazda Tribute 2002 model that the remote will not work on. i bought a new remote with the same number on it 1L87T-15K601-AA and I cant program it I have done the turn key 8 times to get door...
These are the correct instructions.
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. Door
locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle to confirm
programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will cycle again to
confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Jun 22, 2012 | Cars & Trucks
How do you program the key flob? Can you do this yourself our is this a dealer job. If yes to the dealer any other way to have this done cheaper? This is a 2000 ford windstar with 4 buttons on the remote.
From the owners manual.
RUN. Door locks will cycle to confirm programming mode.
to confirm programming.
cycle again to confirm programming.
Apr 09, 2009 | 2000 Ford Windstar
How to program the key for my bmw 750i model 1997 to lock/unlock the door
BMW 7-Series - Key Remote Programming
Three methods to try:
Method 1:
1. Working from within the vehicle and with the doors shut
2. Turn ignition to position 1 and back to off within 5 seconds.
3. Remove the key from ignition and press and hold the unlock button for 15 seconds during this time press the key lock button 3 times within 5 seconds.
4. Release both buttons.
5. Doors will lock and unlock to show correct programming has occurred.
Method 2:
To do this procedure you need to have one working key and one key that needs to be programmed.
1) Get in and close all doors.
2) Turn on the ignition and turn off quickly. (No more than 5 seconds) to start the process. Next action must take place within 30 seconds.
3) Remove the 1st key.
4) Hold the key up near your left shoulder (this is so it is closer to the remote receiver antenna.
5) Hold down the unlock button and press the lock button 3 times. Release the unlock button and the doors lock which confirms the operation.
6) Quickly repeat steps 4 & 5 for key #2 etc.
If it does not work, try doing the keys in opposite order. Key 2 then key 1, vs 1 then 2.
Method 3:
Alternate if you do not have a working remote
1. Turn key to position 1 five times very quickly 2. Remove key 3. Hold unlock button then press lock button 3 times, release unlock button.
4. If you have another key do the same button pressing within 30 seconds 5. Turn on ignition to finalise.
PLEASE NOTE: This programming procedure programs the remote control part of the key. Any transponder chip for the immobiliser (starting of car) will not be programmed and must be done by a specialist.
window.google_render_ad();
Dec 16, 2008 | BMW 750 Cars & Trucks
Remote key will not open door
hi, gareth hear
i think this mite work 4 u
get in your car and put key in ignition turn 1 turn then wait approx 15 20 secs for light in clock to go red then take key out light should stay lit, next get out of your car close door then lock it and open it, when u open car light in clock should flash 3 times, next get out of car hold lock button on your remote down and push open button 3 times (keeping lock button down and remote pointed at reciver) next lose go of both buttons and red light on key should flash 3 times at the same time as clock inside the car.
next get in your car with key! then start her up and turn off get out of car close door and push button to lock (it should lock) if not get back in start her up again and turn off, then push the door locks inside the car then open get out and your car will lock this time!!!!!!!
this will work 4 u!!!
good luck
Dec 14, 2008 | Code-Alarm Code Alarm Transponder
How to set up for 2005 pacifica garage door opener
how about a real answer......
1. Press and hold the two outer HomeLink buttons, and
release only when the indicator light begins to flash (after
20 seconds). Do not hold the buttons for longer than 30
seconds and do not repeat step one to program a second
and/or third hand-held transmitter to the remaining two
HomeLink buttons.
2. Position the end of your hand-held transmitter 1-3
inches (3-8 cm) away from the HomeLink buttons while
keeping the indicator light in view.
3. Simultaneously press and hold both the HomeLink
button that you want to train and the hand-held transmitter
buttons. Do not release the buttons until step 4
has been completed.
4. The HomeLink indicator light will flash slowly and
then rapidly after HomeLink successfully receives the
frequency signal from the hand-held transmitter. Release
both buttons after the indicator light changes from the
slow to the rapid flash.
5. Press and hold the just trained HomeLink button and
observe the indicator light. If the indicator light stays on
constantly, programming is complete
and your device
should activate when the HomeLink button is pressed
and released.
Dec 11, 2008 | 2005 Chrysler Pacifica
1999 civic key fob reprogramming
Oct 25, 2008 | Honda Vehicle Parts & Accessories
Remote entry key.
You may have lost programming in the remote.
Here are the instruction to program it
1. Confirm that all doors are closed and the ignition key is NOT in the ignition cylinder.
2. Open the driver's door and within 10 seconds insert the key in the ignition.
3. Now, within 10 seconds remove the key from the ignition.
4. Within the next 20 seconds, push and release the driver's door switch 3 times. This is the switch near the door strike plate which turns on the inside light and indicates that the door is open.
5. Within 10 seconds, insert the key in the ignition.
6. Now, within 10 seconds remove the key from the ignition.
7. Within the next 20 seconds, press and hold both the LOCK and UNLOCK buttons on the transmitter. Hold both for at least 5 seconds. All the doors will lock or unlock to confirm that procedure was done properly.
8. Within the next 5 seconds after step 7 was complete, press either the LOCK or UNLOCK button to confirm that this process has been properly done. Now, the transmitter has been programmed.
9. Repeat steps 1 to 8 for additional transmitters.
10. Operate each transmitter to verify the programming.
Sep 04, 2008 | 2004 Suzuki Verona
Battery died now power sliding doors and rear hatch not operating
1) Unlock all doors from driver's door while it is open. The driver's door is the only door to remain open during this process! 2) Turn the key from OFF to RUN 8 times within 10 seconds, with the eighth turn ending in RUN. All the doors will lock and unlock if program is successful. 3) Turn key OFF and remove key from ignition. Within 20 seconds, press any button on the remote. (Press sliding door or rear hatch and it will open!) 4) If door locks do not respond, wait several seconds and press button again. If doors still fail to respond, try repeating steps (1-3).
Jun 16, 2008 | 2005 Ford Freestar
Kenmore elite 790.3670 oven door locked
I held down the clear button for three seconds, it unlocked but still showed the lock button lit. It began beeping over and over. I opened the door and pressed the clear button again for three seconds. It stopped and the oven works just fine now. In fact, I used it right after I got it cleared out.
Feb 07, 2008 | Kitchen Ranges
Dishwashers Logo
Top Dishwashers Experts
