Question about Dryers
I am looking for a service manual for a Philips D153 Drum Dryer
    President:
  • 3,074 Answers
This is a good site:
http://www.appliancerepair.net/dryer.htm
Hope it helped Tim
Posted on Oct 16, 2010
  • Dryers Master
  • 19,396 Answers
The appliance was built by LG. The service manual is available at the link below:
CONDENSING DRYER SERVICE MANUAL
Posted on Dec 15, 2011
My dryer won't spin and is squeeling
It sounds like either the belt is loose or the drum is frozen. Try the following links to see if they help.
Appliance411 Home Service Appliance Repair Manual for Whirlpool Kenmore...
This will help if you have never repaired a dryer.
User Manual Downloads
Feb 05, 2016 | Kenmore HE2 6.7 cu. ft. Gas Super Capacity...
Dryer is less than five years old. there is power to the dryer but it will not turn on.
Unplug the dryer. Get the back off of it. Pop the top get the drum out. Look for reasons why the dryer would not work. A broken door switch or a tripped duct fuse is what I would check
themobilian_2879.jpg. themobilian_2880.jpgthemobilian_2881.jpgthemobilian_2882.jpgthemobilian_2883.jpgthemobilian_2884.jpgthemobilian_2885.jpgthemobilian_2886.jpg
I have a service manual and more HERE
Bonus: Dryer tune-up
Aug 22, 2011 | Kenmore 400 6942 Dryer
Hi, I have a bad knocking or rumbling sound when the dryer is on-- I think it could be something that the drum is rolling on? glides? or a slipped belt--? There is a 1-2 second hesitation in the noise when...
Look inside the dryer for a cracked drum, sometimes its easier to spot when you turn the dryer drum manually slowly with your hand. it should be in the back area depending on what brand of dryer you have. Good luck!
Mar 23, 2011 | Dryers
The dryer is hot to the touch inside the drum
two issues the heat thermal relay or the fan motor quit working you can go to www.appliancepros.com and look up the parts list for your model.
Apr 14, 2010 | Amana DLE330RAW Electric Dryer
I have a 2006 Whirlpool Duet Electric Dryer that leaves brown marks on my cloths. I have cleaned the inside of the dryer per the manual's diretions, but it still leaves the marks. They almost look like...
Usually, if you are getting brown streaks or marks on clothing, one or both of the drum seals are going bad. Clothing will drag between the bulkhead and the drum, leaving brown marks. If you want to do the repair yourself, I can provide instructions, otherwise call for service.
Dec 30, 2009 | Whirlpool GEW9250 Electric Dryer
Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Mar 01, 2009 | LG DLE2532W Electric Dryer
Do not know how to open up machine to look inside
Hello willdano,
Here is a link to the LG Website. Included in this link are all the service details, specs and documents you will need to repair your dryer. http://136.166.4.200/contents/Laundry/DLG5988.htm If you access the service manual, check out page 29 & up for disassembly details on how to access the internal hardware. Hope this helps.
Regards,
Rick
Jan 04, 2009 | LG DLG5988 Gas Dryer
Ne Frigidaire front load dryer AEQ7000E1 - drum won't turn
Tell you what i am going to do post your email here and i will send you the Service manual
Jan 26, 2008 | Dryers
Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
239 people viewed this question
Top Dryers Experts
