Question about Miele KFN8762SDED Bottom Freezer Refrigerator
Occasionally my freezer will defrost and will make a big puddle of water on the floor.
  • 22 Answers
The drain from the freezer is probably plugged as well theres a drain pan under the fridge , look underneat an u will probably find the problem , make sure the drain pan underneath is not full of stuff
Posted on Oct 16, 2010
Occasional puddle of water on the floor that is coming from the freezer area
All refrigerators have a drain. This is for when your unit goes into a defrost mode. You do not have to empty your drain pan because the water evaporates by the heat of the compressor. If you have a side by side unit. Open your freezer door and remove the lower drawer down by your feet. If it is frozen in there by ice or if when you remove it there is ice on the bottom. It is your drain that is clogged. Any other questions. You can click contact Apco Now..
Apr 04, 2013 | Maytag Refrigerators
I have a Kenmore refrigerator. Model 596.65234404, serial number ky3257801. Occasionally there is water forming puddles on the floor in front of the refrigerator. What maintenance procedure can I do to fix...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Aug 24, 2011 | Refrigerators
Frigidaire Ultrafreeze upright just stopped working
It sounds as if your compressor it's running. This could be a bad compressor, bad capacitor, bad thermostat. See that there are no fans or defrost, it is one of the other. I would start with checking the capacitor. You can replace it with a Supco 3 in 1. It cost around $30.00. Anything else is going to start costing $100.00 and more. If you need a freezer that big, I would have it fixed unless it ends up being the compressor.
Please rate solution
Sep 04, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Frozen water covers the floor of my freezer
Something less serious I think. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 14, 2009 | Refrigerators
First thing this a.m. we discovered a puddle of water on the floor on the left side of the fridge. This is not the first time....so we are wondering what is causing this? I am guessing about the profile #...
You have a plugged defrost drain.
Unplug refrig. Unload freezer. Remove shelves. Take back panel out of freezer. Use a turkey baster with hot (not boiling) water to flush water in the area of the defrost drain hole until it is clear and water will run through it into the defrost drain pan under the refrig. The drain is a hole about the size of a nickel, usually in the very back center, below the cooling coils. You can use the turkey baster to force water into and eventually through the drain hole. Remove ice from floor of freezer.
Re-assemble, refill freezer, and plug in. Now, when your refrig defrosts, the water will go out the drain instead of onto the freezer floor and out the freezer door onto your floor.
Aug 05, 2009 | GE Profile PSI23NCR Side by Side...
Water and ice in bottom of freezer, occasional water on floor
I believe your defrost condensate pan below the evaporator is blocked with ice and now when defrost happens the water pours over the tray and to the bottom of the freezer. You will need to defrost the ice in the collector tray and the pour a solution of hot water and clorox to make sure the water ends up in the condensate pan below your refrigerator. So unplug the refrigerator remove the panel and let me know what you find. I have some more solutions depending on what you see is happening. Thanks, Sea Breeze
Jul 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Occasional leak at the bottom of the freezer side kenmore 25354703400 side by side
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 15, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Freezer Defrosting
After a defrost cycle the ice around the evaporator melts, that water goes out and lands in a tray under the refrigerator. But sometimes the tube gets clogged and water spills inside the freezer and if enough water accumulates, it will make it to the floor. To fix this problem look for a small hole inside the refrigerator and open it up using a can of compressed air. Hope this helps
Aug 05, 2008 | Freezers
Miele KFN8762SDED Bottom Freezer Refrigerator Logo
213 people viewed this question
Top Miele Refrigerators Experts
AJMAL KHAN
JonSnell Electronic
JonSnell Electronic
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
