Question about Sony KP-53HS10 TV
Screen went out, sound works but screen does not. Power on light flashes 7 times on start up
    Top Expert:
  • Sony Master
  • 75,581 Answers
Flyback transformer [LOT] short. Replace the same with similar type and number, and replace the horzontal output transistor alongwith it.
Posted on Oct 17, 2010
Washer stopped in mid wash. Clean light came on and flashes 7 times. Pressed clear went to 2 and finished. Pressed start light flashed 3 times won't start.
remove the bottom kick panel,you'll see a tech sheet there in the plastic bag,it will tell you how to check to see if the heater or board is bad,the light will flash 7 times,it's an error code telling you that there's a heat problem.
Feb 20, 2015 | Dishwashers
Tv does not turn on
If green light flashes more than 8 times, it could be as simple as repairing or replacing the power supply. Unplug the TV ,remove the back. Look for bulged or leaking capacitors on the power supply. Do it yourselfer? only if you have soldering skills, or purchase replacement board. remember, used boards are just as old as your failed board, buy new or rebuilt, Good Luck
Feb 17, 2014 | LG Televison & Video
My screen just went black
Hello, if the Toshiba monitor went black: 1)if there is power from the monitor, check power cable and data cable 2)make sure that its properly connected to the computer 3)make sure computer is on and there is an activity from the computer 4)if the is sound from the computer try a known good monitor if that will work 5) try this Toshiba monitor to a working computer 6)try checking the monitor maybe the back light is busted get a flash light point it directly to the screen it self check if you can find something 7)if all is done bring monitor to a repair station if in warranty manufacturer Thank you for using Fixya
Mar 06, 2011 | Toshiba Computers & Internet
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
New lamp turns on flashes 7 times
Just a thought...you *might* have a bad ballast in addition to that defective power supply.That flashing could be the ballast trying to ignite the lamp. A lamp is just like an enclosed welder's arc. The ballast generates a high-voltage spark to initially start the lamp, then low voltage with high current keeps it burning. If you look into the lens and see "lightning" flashes but no lamp ignition, that's what's happening. The ballast could've been damaged by the defective supply. Also, try a known-good lamp...just to rule out a defective new one--in the shop, we kept all old working lamps as testers.
Aug 30, 2009 | Sony XL-2100U Projector Lamp for...
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Power/standby light flashes 7 times and the tv doesn't turn on
Audio Protect (7 Flash): When DC voltage is detected at the speaker or
woofer outputs, IC3604/pin128 (TV-micro) goes low and IC3604 turns off
the main power (AC relay turns OFF).
Troubleshooting Tips:
1) Main cause of defective will be located on the KD-board
2) Confi rm KD-board is securely seated on the G2-board
3) Replace KD-board
Jun 13, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KP-53HS10 TV Logo
43 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
