Question about Kenmore 96422 / 96424 / 96429 Electric Kitchen Range
Kenmore electric range 93521 / 93525 / 93821 / 93829 / 93845 / 93846 / 93849. Surface unit indicator light remains on. Elements are off and are cool.
  • 49 Answers
SOURCE: cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Posted on Mar 08, 2008
jazzyboy11
  • 728 Answers
SOURCE: The hot surface indicator light remains ON all the time.
Your hot surface indicator light might have a short that causes it to stay on all of the time. If you can, try unplugging it for a little while and plugging it back up. If the light is still on, you have a short. You can still use the stove, but the light staying on will not be any help to you.
Posted on Oct 22, 2008
Maytag317
  • 1136 Answers
SOURCE: 0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
Posted on May 17, 2009
Maytag317
  • 1136 Answers
SOURCE: Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
Posted on May 30, 2009
marka19
  • 1430 Answers
SOURCE: Have a Kenmore electric range.
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Posted on Oct 23, 2010
I have a Kenmore stove model 790.92402013 and oven is not working. Surface elements work. When the oven is cut on, there is a slight pause before the oven light shows on the control panel please help.
You should be having one of about 4 problems.
1) A wire could have burned into two parts inside the oven in the area of the connector. ( or somewhere else )
2) The heating element could have burned out.
3) Where the heating element is connected to the feed wire could have failed.
4) The control unit that tells it what to do has failed.
The first 3 you can see when you take it apart.
The last one could require an electrical tester.
God bless your efforts.
May 01, 2018 | Kenmore Kitchen Ranges
Hot surface indicator light stay on?
One of your surface elements is bad (the hot-element switch that is part of the element is stuck on). If each element has its own hot-light, then you know which element is bad; but if you have just 1 hot-surface indicator, your problem is figuring out which element is bad. That takes an electronic technician with patience and an ohmmeter.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 24, 2014 | Whirlpool RF378LXKS Electric Kitchen Range
I have a kenmore electric range. Model C970-615022 The right front burner doesn't heat up at all. The light on the switch indicates that it's on but nevertheless it doesn't get warm. This burner has the...
If this is an older unit, the quick connectors and the element contacts are prone the burning and loosing contact. I am talking about where the actual burner snaps into the connector. On the one I used tro have, the indicator light would illuminate, but the burner would stay cold. The elements and the connectors can be replaced, but make sure the power is disconnected before servicing it. For a wiring diagram, I would contact (sears.com)
Sep 05, 2014 | Kitchen Ranges
Hot surface light indicator stays lit
The hot surface light is controlled by a part attached to the element called a limiter. For your model, the limiter is not available as a seperate item. The element/limiter assembly has to be replaced as a single unit. The top assembly, elements and limiters are all fragile parts.
If you are making this repair yourself, make sure the range is disconnected from it's power source prior to service.
Apr 27, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Oct 22, 2008 | Frigidaire FEF366EC 30" Freestanding...
Smooth Top doesn't cool down ????
does the lindcator light remain on nall burners cold to touch?, or is the element actuall on low?? if just the hot surface indicatoris on and elelmnts are cold to touch you hae a bad element. if the elemnt wont shout off the problem is in the switch. i would ck with manufacture depending on age you may have a part warr for 5 yrs on the elemnt itself
Mar 12, 2008 | Kenmore 92420 / 92421 / 92422 / 92424 /...
Cooktop light stays on when cool
Mar 08, 2008 | Kenmore 95002 / 95004 Electric Kitchen...
Surface unit indicator light is always on
Coffy, if you are talking about the hot surface indicator lights, they are controlled by the limiter on the burner itself. When the burner heats up the limiter closes and sends power to the light (hot surface). When the burner cools the limiter is supposed to open cutting power to the hot surface indicator light. They may be stuck closed. If you are talking about the lights on the back panel, that is controlled by the infinate switch itself. Catriver
Oct 09, 2007 | Kenmore 96012 / 96014 / 96019 Electric...
Kenmore 96422 / 96424 / 96429 Electric Kitchen Range Logo
199 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
