Question about Maytag Washing Machines
Maytag automatic washer lat8200 water does not shut off
Maytag washer large load overflows
Posted on Apr 24, 2009
    Champion:
  • 210 Answers
More than likely the valve is bad. Is it hot or cold, this way you will know which one to get.
Sgt 48
Posted on Jun 03, 2008
Washer wont pump out the water and wont shut off if not unplugged
Heres a great website: Go there and investigate the videos
http://www.repairclinic.com/Shop-For-Parts?SearchText=Maytag%2520Neptune%2520FAV6800AW
Feb 18, 2015 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune MAH 6700 AWW. It is shutting off and giving error code tE. Customer service does not recognize the error code. Can you help?
This is a problem with the signal from the water heating element "Thermistor" a Thermistor is a solid state sensor that senses temperature, in this case water temp. The Thermistor is part of the washers water heating assembly and not sold separately from it. There is a factory repair bulletin associated with the problem and the new part has improved reliability. I can't understand what the Maytag folks you called would tell you it is not listed, it is a common fault in the Neptune. Please rate my help. Thanks
Jan 23, 2012 | Maytag Neptune MAH5500B Front Load Washer
Washer immediately goes into wash cycle when filling with water on initial start.At the end of the spin cycle ,washer dumps water back in to drum.Also,it's not getting the detergent out of clothes. Maytag...
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 26, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
Maytag washer does not stop running water; it keeps filling up with water even if I push the bottom to shut down the washer
Sorry if you can't get the automatic valve to close or the float switch unstuck, the only other option is to call in a repairman BTW what happens if you just pull the plug, does it still keep filling?
Dec 08, 2009 | Kitchen Appliances - Others
Maytag neptune starts to fill with water then stops
Water inlet valve sounds faulty.
Fill s to slow so it automatically shuts off.
Not a do it your self problem.
Apr 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune stackable washer dryer stopping
Maybe a water fill problem ,washer will stop if no or not enough water enters the tub in a given time
Dec 04, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Washing Machines Logo
149 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
