Question about Fisher and Paykel Washing Machines
Hi my machine keeps beeping whilst filling up? i have to keep starting it off from scratch to get to fill up, then it will do a cycle no problem until its time to spin, the motor sounds like its going to start spinning and then it just starts beeping again, we have checked the pump in case something has worked down there ie sock but all is clear
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now 1st I need to know the model number of your machine which is on a sticker at the back of the machine top left.Also when the machine is beeping it will show a series of lights that will light up.These lights will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine is beeping,Is it the 2nd and 4th or the 1st and 7th ---etc---?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Oct 16, 2010
My idesit IWB5113 just keeps filling after starting the wash cycle, normal it inject some water then starts washing, my machine just keeps filling and doesn't seem to start the wash cycle, please help
It is possible that the water level sensor has failed and so does not detect to stop the inlet valve from filling.You can remove and check this level sensor normally it can be a damaged diaphragm and replace the same so that the program proceeds to the next stage to start the machinetips to see working of the machine;http://www.espares.co.uk/advice/washing-machines/a/7/1392/how-a-washing-machine-works.html
Mar 14, 2012 | Washing Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
The machine keeps filling up at the end of a cycle so I have to make sure I empty it in time.
If the water keeps filling, your water level sensor is probably bad. If it keeps filling at each cycle, your washer may be out of time.
Mar 03, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Hoover 700 LA keeps overflowing
Hi just read you posting.Now fortunately I have the same machine.Just a couple of questions.--1-- does the machine flood at the start of the cycle when it is filling for the wash or in the rinse cycle? 2---At anytime while it is filling does it start to wash? Now try this for me, Turn the machine on at the start of a cycle so it starts filling and then when you hear the water going into the machine turn the power off at the power point. After you turn the power off at the power point can you still hear water coming into the machine?Please reply with additional information to the questions because with those questions answered I will tell you the exact fault and guide you throe the repair.
Jun 20, 2010 | Washing Machines
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
KEEP GETTING E70 MESSAGE
Are you sure its a E70? If so, the hot and cold lines are reversed.
Apr 25, 2010 | Frigidaire GLTF2940ES Front Load Washer
Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
Nov 19, 2009 | GE Washing Machines
Keeps filling with water when turned on
A lot of wahing machines use a bunch of micro-switches to turn the various solenoids on and off. If your washer has that type of switch, it could be sticking, subsequently sending an "on" signal to the fill solenoid.
Apr 19, 2009 | Washing Machines
Washing Machines Logo
50 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
