Washing machine dosnt spin dry, front loader westinghouse mastermind 708, 7.5 kg
  • Anonymous Mar 22, 2014
    My westinghouse mastermind 708 is filling up with water and not stopping. It only does it on the wash cycle not the rinse cycle at the moment. Any suggestions as what the problem is...and the solution? Thanks :)
    President:
  • 1,314 Answers
Remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
Posted on Jun 03, 2008
My mastermind 708 dosen't spin after wash cycle.It spins fine in the wash cycle but dosen't drain water or spin in the spin cycle.Pease help
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
Jul 01, 2011 | Westinghouse Washing Machines
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
My westinghouse mastermind 708 is flashing SE or 5E? what does this mean please?
most home appliances have many ELECTRONIC components......these components are very sensitive to electrical irregularities that enter your home electrical system......these irregularities can cause some components to freeze up.......pull the plug and leave your westinghouse 708 unplugged for several minutes.......plug it in again and it will reset all of these control components........hope that helps!
Jan 07, 2011 | Westinghouse Washing Machines
I have a Westinghouse mastermind 708 washing machine and it does not spin after wash cycl. i think it might be the pump to pump water out, it still makes a humming noise
I would check the internal coin trap/drain to make sure it is not blocked with socks or 3-in1 dryer sheets. If the water does not drain it backs up and causes error messages and spin problems. These are normally not listed in the manual so you have to take off a panel to find it. Could be at the bottom or in the back. Unscrew and check the trap and remove any blockage. Prepare for a mess if you can't fit a bucket under the trap!
Oct 23, 2009 | Westinghouse Washing Machines
Dirty smelly front loading washing machine
you need to find and clean the water return filter
Oct 11, 2009 | Washing Machines
Door lock on westinghouse mastermind 708 washing machine
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened.
Apr 13, 2009 | Washing Machines
Error on Westinghouse mastermind 708 front loader washing machine
This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash)
- Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver)
. My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
Oct 21, 2008 | Washing Machines
I have a mastermind 708 7kg front loader and SE is flashing and maching won't work can you help please
Ihave a mastermind 708 7kg front loader and the SE is flashing and machine wont work can you help please? Thankyou
Aug 03, 2008 | Washing Machines
Washing Machines Logo
515 people viewed this question
Top Washing Machines Experts
