Question about GE Profile 25.5 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Want to attach a water filter. no filter came with the frig/freezer
    President:
  • 1,891 Answers
G E does have a add on filter . ( its in line and works with a 1/4 palstic or copper ) very easy to install just cut the line ( make it a true 90 deg and just plug it in / good for 6mo or about 2000 gal . takes care of taste and other minerials . hope this helped mm ..
Posted on Oct 16, 2010
I have a side by side whirlpool, water was coming out fine then replaced with new filter and a month went by the water started to come out very slowly I thought the filter may be plugged so put anothe
Cut water supply off to frig disconnect water supply line to frig water inlet valve turn water back on to make sure you are getting good water supplied to water inlet valve some times water cut off gets stopped up. If you are getting good water flow to water inlet valve then check to make water valve is opening up all the way. if not then replace valve.
Oct 27, 2014 | Whirlpool Refrigerators
REMOVE THE FREEZER DOOR
Did you follow the tubing farther underneath the frig?
Sometimes there is a coupler that attaches to the rest of the tubing going under the frig to the water reservoir which is usually in the frig under or behind the cripers drawers.
Dec 16, 2011 | Hotpoint Refrigerators
Water filter for ed0gtqxkq00
I looked up your frig and I did not see a filter. If you want to use one, you can install what is called an inline filter. This is simply a filter you install behind the frig attached to the water line going to the frig.
All you have to is unhook the water line from the frig, attach it to your newly bought inline filter, and install another water line on the other side of the filter and hook that back up to the frig!
So now you have a filter and two water lines :) Just make sure to point the filter the right way, the usually have an arrow on them. The water is supposed to flow through them in a certain direction.
May 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My water dispenser does not give me water
1st make sure you got water to the frig.
defrost the frig by turning it off for 2 days with the doors open. Sometime the water freezes inside the door and the water dispenser doesnt work. the turn back on and see if you have water. every 6 months you should change the filter (it could be the problem too)
Mar 27, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
How can we increase the water flow to the inside filtered water spigot?
Has the filter been replaced recently. If not replace it. If it has, then check the tap the supplies water to the frig and the supply line for kinks. If the line is not kinked, open the tap valve all of the way.This should increase your water pressure to the frig.
Jul 12, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Fishy smell in frig
Change the filter. Depending on your water supply and where you are located, you will get a buildup of junk that smells like fish.
It should be changed about every 6 months.
Feb 17, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Water in the frig and possible overheating
clean the coils and check to see if the condensor fan is working. Call your local dealer and ask them to order you new o-rings for the filter mount to fix the leak from the filter.
Jul 19, 2008 | Frigidaire FRS26R4A Side by Side...
GE Profile 25.5 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
42 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
