Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
I have a whirpool side by side frig WITH DOOR ICE MAKER and need to know how to get AUTOMATIC ice maker in so door will shut model ED226WXFW02
    President:
  • 1,891 Answers
Looking at your model the ice maker is mounted and is not removable . so maybe you mean the ice storage bucket. . make sure the rails are clear and it should slide in and when all the way in lift up and feel the click into pos . this lock the bin so the augar can work . and the door should shut .. hope this hepled mm and thanks for using fix-ya ..
Posted on Oct 16, 2010
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
Model gd25dfxfw00 Gold side by side; air appears to be leaking around the ice maker ejection door creating a build up of ice inside the freezer at the bottom of the icemaker ejection slot.
I had the same problem, same Whirlpool frig.
There's damper/delay arm/plunger, similar to what you see on doors, that slowly closes the ice door to allow all the ice to escape. This is stuck/broken. You can order the parts on line and replace it. I actually just removed it and the door closes nice and snug again, and no more ice build up in the chute. It occasionally traps ice in the chute, as the door shuts real quick now, before the last cube(s) can come out. I'm use to it now and am quick to open the door without sending more ice out of the maker.
The replacement kit should be : AP3595356
May 21, 2010 | Refrigerators
I have a kenmore side by side refigator and with built in ice and water in front door. The water does not fill ice maker or dispence out the door. The water stoped first at door then about one year later...
you might need to open the water pip and clean the volve on the bottom of your fridg. its get clug some time but if its not working then your valve need to be replace..get me your model # i get you the part#...
911servicetoday . com
Jan 01, 2010 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not getting water from water valve
you will need to replace the water inlet valve on the lower back of frig.easy,let me know how you do-mike
Oct 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
Kenmore Refrigerator Ice Maker
it sounds like your inlet water valve is not closing all the way,pull frig out turn water off,remove valve get model number from inside the frig. and replace it,let me know-mike
Jul 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
78 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
