Question about Frigidaire FEF366 Electric Kitchen Range
Show me how to install a part for my frigidaire stove top the switch has change
    Sergeant:
    Champion:
  • 277 Answers
Sharon,
Pull out stove from the wall,
Unplug stove. Now you are safe!
With a phillips screwdriver, remove the backpanel.
The switch you are replacing, remove knob.
Remove the two screws that hold the switch in place.
When switch is free, remove one wire at a time, and make sure you put them on the new switch as you remove from old.
Fasten switch in place, close up the machine. plug it in
Enjoy your new buner
bweazer
Posted on Oct 16, 2010
How to remove the stove top on frigidaire stove model FFGS3025PS
IF you open the door to the stove, you will see screws under the lip of the cook top, take those out, check the back of the stove for screws and then lift the cook to. On some models you may have to remove the sides of the stove too.
Mar 13, 2016 | Frigidaire Stove/Oven/Range Cooktop -...
My frigidaire stove made a loud pop while oven was on and then lost power....stove top elements working stove clock not working tested fuse, and changed it still not working
Thank you for your post, friend!
I understand that your Frigidaire range made a loud pop while in operation and lost power. I noticed you stated that the stove top is working and you have changed out the control board but the oven is not working. It could be a possibility that your terminal block or wiring harness has shorted. I would recommend contacting a professional technician to come out and perform a diagnosis and repair on your range. This will help to avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Feb 24, 2015 | Frigidaire Kitchen Ranges
Frigidaire glass top stove dual element ony works on high no matter were knob is set
Hello Chad;
My name is Peter. I am a retired field service appliance technician.
It sounds like you have a bad Warmer Infinite Switch.
Once installed, the switch controls your gas range's warmer drawer element. When replacing your gas range's switch, consider replacing its knob (PartsDirect part number 316442403) if it shows significant wear.
To replace your gas range's warmer infinite switch, pull the knob off the switch and remove the screws securing it. Disconnect any wires running to the switch and take note of those connections. Remove the switch and put the new one into its place, reattaching the wires to the same terminals. Be sure to unplug your gas range before beginning the repair.
25433033-yqd4wkymfcifmtxqtu0sd2am-5-0.jpg Part #: 316095500 Cost: $32.00
It is located on the right hand side of your display panel. You have to remove the side panels screws and control panel back to access.
Feb 15, 2015 | Frigidaire Kitchen Ranges
Need a wiring diagram for a rse37bal3
Your Frigidaire motorcycle has an electric stove?
Most stoves I have worked with in the past have had the wiring diagram glued either to the back or under the top. I have never seen one installed on a motorcycle, however.
Feb 16, 2013 | Motorcycles
Stove top
YOUR SWITCH IS BAD FOR THAT BURNER REPLACE THE SWITCH AND YOU WILL BE GOOD TO GO
Jan 07, 2009 | Frigidaire FEF351C Electric Kitchen Range
I did not follow directions on self-cleaning and now stove is loc
Since the door is open and the lock is engaged, you will need to hold the "door closed" switch in located in the top left door opening. Push and hold the switch in, push the clean button, set the time at 3:00 hours, keep holding the switch in for 20 seconds, then push cancel button. The motorized locking mechanism should disengage. Then, you can release the switch. Hope this helps.
Dec 06, 2008 | Frigidaire FEF352 Electric Kitchen Range
How do I adjust the flame on my Frigidaire model FGS383BADK stove?
its going to be listed in the installation manual ,not use and care, youre going to need to convert oven for lp gas. i would call the manufacture with the modelk number and ask for hte coorect conversin kit, for such a thing
Nov 03, 2008 | Frigidaire Ovens
Replacing range top to flat
That could really be a very costly change over. You will have to replace the top ($400.00) each element ($85 to $130.00) each, and probably some wiring and switch changes. You can prbably get a new one for way less than switching one over. You might be able to find the parts on ebay, etc, its just going to be matching the right parts. Good luck, and let me know how it turns out.
Aug 05, 2008 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire FEF366 Electric Kitchen Range Logo
125 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
