Question about Samsung PCL545R 54" Rear Projection Television
Problem with green tv would not turn on
Thanks fo the help! Now my question is- I found the ics stk392-040 but I also found a replacement board that the ics and heatsink is located on. It is called a sub delf board part #aa95-00705a, now will that come with ics allready installed on it? And will that fix the convergence problem and allow the tv to turn back on?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 92 Answers
Yes board should come with ICs and you should   " Fly like an Eagle !!"
Posted on Jun 08, 2008
The tv will flash a green light and will turn off, it doesnt turn on either when you power it on
if the green light is a flash on screen with retrace lines most likely the video driver ic on the green crt board , just take the speaker grill .
theair should be a way to get to crts. the one in the center is the green crt. the green video driver ic is an inline 24 pin ic.
to test unplug the video drive plug leading to green crt board turn tv on .if it comes up its a bad ic.
if not unplug the crt socket ,and try to turn it on if it comes up
bad crt internal short hope this helps, butler
Oct 02, 2016 | Televison & Video
Hitachi Projection TV that has no picture, there is a clicking sound from inside when tv is on. Taking off the rear panel reveals there is a green blinking light on the board that is blinking. Recently...
Due to the fact that you recently replaced the convergence ICs I would look at that area. Check all the resistors, diodes and semis for any problems. If none are found use my tip at to help troubleshoot your unit.
Thanks for using FixYa and for the great rating.
Jun 07, 2011 | Hitachi 46F500 46" Rear Projection...
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a panasonic PT-47wxc43 projection tv. I have green and purple halos coming up from the bottom. The screen has purple and green double images which are worse from the bottom up.
This problem is due to convergence output ICs failure and both chips will be replaced to fix the issue.
There are two big black ICs installed with aluminum heat sink on deflection board, these are convergence output ICs and will be replaced to correct the problem, it is common problem of rear projection tv.
Below image of deflection shows ICs (marked in red) that are need to be replaced.
IC number is STK392-110 and available with Part Store for $32 each.
Click above link to see an image of IC.
If you are handy with electronics stuff repair and can replace parts in tv circuit board then can replace these parts yourself or ask local tech to help you.
Hope these info will help you.
Let me know if you have additional question.
May 25, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
Jvc projector tv changed ic's now will not power on
Resolders the FBT,the big block plastic with a red wire solder to a board.
Dec 23, 2009 | JVC AV-48WP74 48" Rear Projection...
LG plasma have an amber light when turning on then green then red
After all the research I found out that the IC on the Z board is bad and new board was ordered and replaced. The plasma work fine after that and picture is excellent with the new board. This forum is great, without this I couldn't fix it myself. Thank you.
Sep 30, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Mitsubishi ws 65819
Ur power board ic converter it dead.
Ur Convergence board is bad going to die to.
Both must change.
Aug 15, 2009 | Mitsubishi WS-65819 TV
Hitachi 51UWX20B no sound, no picture, blinking green LED
The 392-150 is a higher current device then the 110---you can use either--this is normal in the hitachi sets---I usually replace both with 150's---check the led that does not light---should indicate which voltage source is bad---if it is one of the 2 voltages for the convergence ic's(one is a positive and the other a negative voltage) then the convergence Ic's may be bad---look for any discolored resistors around the ic's---one way to tell if it is a convergence ic is to de-solder both ic's and see if the set turns on(the convergence will be out the window) but if it comes on change both and do the alignments with the Hitachi remote. By the way----the led should have a location number printed on the top of the circuit board.
Aug 07, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 46F500 46 in. is still bad
if you found the burnt resisters after you replaced the ic you probably burnt the ic out again,
Jan 24, 2008 | Hitachi 46F500 46" Rear Projection...
TV Won't Stay On...
I had a service some out and they replaced the amps and the TV has worked fine since then....
Nov 15, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Samsung PCL545R 54" Rear Projection Television Logo
194 people viewed this question
Jerry Greenberg
Jerry Greenberg
