Question about Toshiba 32A50 32" TV
Is it possible that the remote sensor can burn out? The remote that came with the TV won't work and neither will the satellite remote which is programmed to run the TV. New batteries have been installed in both remotes. The power indicator is lit up on the front of the computer but there is no light on the right side of that box for the remote sensor. If the sensor is burnt out, what does it cost to replace this?
    Top Expert:
  • Toshiba Master
  • 74,496 Answers
Your TVs low power supply rail [5V] is absent. That is the supply rail goes to both remots sensor, power indicator and front keys. just check it.
Posted on Oct 16, 2010
TV remote burns through batteries
Thank you for the reply. In investigating the Ilio Plasma TV, I found if it worked HOORAY. It does. Further investigation revealed resetting the sensor may fix the burned out remote. We have the TV up and out of the way so when we do get it operating again soon, we will try the sensor reset and a new set of batteries.
Dec 28, 2013 | Cameras
I have a Sony Bravia 32" tv that works from the buttons on the side of tv only. It will not turn on from ANY remote (satellite, factory, universal) please don't ask if I have changed the batteries cause...
Check the remote control for its infra-red emission first. If it is found OK, check and replace the infra-red sensor inside the TV. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Details about how to check a remote control is given.
Oct 11, 2013 | Televison & Video
It doesn't work
is this a remote to TV or what? I am assuming it's a remote to a TV. If it is not for a TV, let me know, although, the solution is similar to any unit that uses remote control.
There are three possible causes for this problem;
1. Batteries may be dead inside the remote.
2. Remote might be defctive.
3. TV remote sensor/infrared might be defective.
Battries; Simply insert new batteries into the remote and try again. If changing batterises doesn't help, problem as to be from the Remote or TV's infrared.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Yours sincerely
Elect_Comp
May 14, 2011 | Televison & Video
My remote will not work the tv anymore
there are three possible causes for this problem;
Yours sincerely
Elect_Comp.
May 12, 2011 | Televison & Video
Sharp LC-32SB24U TV. Remote no longer functions.
Unplu the TV from the wall, wait for 30 sec. plug it back in.
Nov 07, 2009 | Sharp 32C-240 32" TV
Remote Controll works inconsistently
Have you replaced the batteries in the remote with newones? If you have, you may have IR interference from some source in yourroom. It could be from a florescent lamp, another player, or even the TV. Isthe receiver in an open space or in an enclosed area? The IR sensor needs adirect line of sight to work properly. You may also check the receiver ifanything is obstructing the sensors, maybe dust. I hope this helps.
Ray Calo
DISH Network
Oct 27, 2009 | DISH Network IR Remote Control
How do I open the menu to program the channels without a remote. I have a sharp TV made in 1989 model #25NV88. I have lost the original remote and have attempted several different univeral remotes, but...
Buy,have the same or an exact remote with this web.site.1-800-remote factory original.
Not possible open the menu,if the tv don't have it in the front of the tv or tside.The IR board very rare to burn,not possible.
Aug 28, 2009 | Televison & Video
Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
Jul 09, 2009 | DISH Network IR Remote Control
Remote
this is from your producer: Product Description ? BASIC OPERATION OK ? everyone knows what a handheld remote control unit does for your home electronics. You can control your basic four (4) components: TV, DVD player, VHS player, Cable or Satellite tuner. Setup is simple for these basic 4? put in the batteries, look up the manufacturer of your component (Mitsubishi TV) and note the possible 3-digit ?program codes?? turn on the component, press the remote control?s PROGRAM button until the light stays red, press the component button (i.e., TV), enter in the ?program code?, and press the ?power off button? ? if the component (i.e., TV) turns off: you are programmed! If the component (i.e., TV) doesn?t turn off, then repeat the sequence using another of the manufacturer?s program codes until it does. Easy ? took me about 3 minutes to program my old Zenith TV (in the bedroom), my SONY DVD player, and my Mitsubishi S-VHS player. No problems at all. HOWEVER, in case you do run into a component for which the ?program codes? don?t work? you can go through a sequence to self-identify the coding. While I won?t go into it here, it is only slightly more time consuming than the other method. As my codes worked fine, I can not address this aspect, so I won?t make a claim we didn?t test.
Jun 06, 2007 | GE HO97685 Remote Control
Toshiba 32A50 32" TV Logo
172 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
