Question about LG enV VX9900 Cellular Phone
When I use my phone to make an actual call, the entire phone gets hot and turns itself off. This is my replacement phone and it does the same thing as the first.
  • LG Master
  • 32,281 Answers
There is something wrong with this phone, it could be drawing too much power from the battery and causing the battery to heat up.
I suggest you return it to the supplier for a replacement or refund.
Posted on Oct 16, 2010
Key goes in on passenger side and turns but wont unlo k or lock
Three things, the actual motor that controls the lock and unlock may be jammed. The actual hinge on the door itself may be sticking, (this car is known for it). And the mechanism that is attached to the lock and motor itself. I've replaced the entire motor and such and it fixed it for a little while. But it just kept happening. I just learned to live with it.
Mar 11, 2015 | 2001 Ford Taurus
My 95 chevey tahoe is blowing hot air and the heater is not even on,what could be causing this?
Most likely, you have a defective temperature actuator. (See diagram below) You can see/get to the actuator by removing the glove box assembly. Turn the ignition on and change the temperature control from hot to cold and/or cold to hot. Watch the white ring on the actuator (See picture) and see if it turns. If it does not turn, replacing the actuator is very likely to fix your problem. (There are other things that can cause this to not work, but most of the time, it is the actuator itself)
If the actuator is working and the temperature coming out the vents does not change, then the blend air door is broken. (This is the part that the actuator moves.) This is also fairly common and requires removal of the entire HVAC housing assembly to repair.
May 12, 2012 | 1995 Chevrolet Tahoe
My blitz broke and the people that were supposed to repair it said it was overheated. any way to fix this??
Generally a phone should not overheat. They get very hot but i've never actually seen one overheat to a level where it damages hardware. It is more likely that the battery has overheated and sacrificed itself instead of the phone. You could try a replacement battery to see if that solves the problem (if you can replace them yourself that is!).
However if the phone is actually fried then I'd bet it is cheaper to buy a new one than diagnose the burnt out piece and replace it.
Aug 30, 2011 | UTStarcom Blitz Cell Phone
My Env Touch resets itself daily!!!!
Mine did that....a software upgrade solved the problem...
Feb 06, 2010 | LG enV Touch VX11000 Cell Phone
Sony WEGA KV30HS420 shuts itself off
Sony KV-30HS420 TV shuts off, indicator light blinks 7 times
Sep 23, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
My palm centro was hot cyncing intself
I just googled this issue b/c my daughter got a hold of my phone and somehow (as only an 8 month old can) hotsycned my phone. O
ut of total frustration at the thought of having to replace my phone, I took the battery out and left it on the counter for about a minute. It works fine now.
Aug 04, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Hello,help me,please.I was updating my n73 Music Edition via Nokia Software Updater,when my PC stopped working.Then,I held my mobile,but I found it turned off by itself.I need your help,please
It won't turn back on huh lindsey? The same thing happened to my n73 while I was updating it. During the update process, it's formatting the entire phone operating software and replacing it with a new one. If the process is interrupted when it hasn't completed yet, it won't turn on anymore. What I did was get my phone reformatted by a technician I knew in the mall. This was in Philippines, so you should ask around where you can get your phone reprogrammed. Let me know how it goes.
Jul 26, 2008 | Nokia N73 Cellular Phone
Overheating
My phone does the same thing!!! I read on another site that if the battery had been damaged or been in freezing weather it would damage the circuitry in the battery itself and cause the overheating.It also said that in some cases the battery had actually exploded! I am going to get a new battery and will let you know if it solves the problem.
Mar 10, 2008 | Samsung Blackjack SGH-I607 Smartphone
LG enV VX9900 Cellular Phone Logo
23 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
