ASUS VW222U Monitor Logo
Posted on Oct 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have AsusVW222U 22 inch LCD monitor I am facing on the middle of the screen Volume window from Asus monitor and right side of the screen one blue line border square Is this issue with liquid or any setting problem Please let me know Raj
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
897
Points
Takeout the powercord at the back of the monitor and wait 5m.
Put it back.
This fixed it for me.
pinoy tekniko
Level 2:
New Friend:
  • Expert 77 Answers
  • Posted on Jun 07, 2015
pinoy tekniko
Expert
Level 2:
New Friend:
Answers
77
Questions
0
Helped
179363
Points
122
try to change the screen resolution of your computer or try to auto adjust the settings of your monitor
thank you
Anonymous
Level 1:
New Friend:
  • Posted on Nov 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
897
Points
Thanks for the suggestion - it worked for me too
Browser windows angrily want a percentage of my big, new monitor
you need to go to the properties of your display settings of the pc. your window size is dependent on your graphics card not the monitor. right click you desktop. goto properties. got to settings. change your resoluton. if you have a better than stock graphics card go to the software that came with the card and change the settings ther.
Screen Display
put your mouse out in the middle of the screen. right click. go to properties. go to settings and slide the res slidebar up to the max.
also, click on start, and with your mouse just on the boarder right click and go to properties, put a check in the box that says hide toolbar.
2answers
Yesterday, a white line appeared in the middle of my screen.
It is most likely a fault in the LCD matrix which makes up the screen. I had one on my 22 inch and it was green. I smacked the left side hard on which it was closest to very hard and it cleared it. If it stays on, take it back if under warranty.
How to fix 22 inch Acer hiorizontal distortion when set at max re
right click on your desktop... select properties.... when that window opens ... click on the tab that says settings. you will see a sliding adjustment there with different screen sizes.... experiment abit till you get the screen size that looks right and that you are comfortable with.
Volume pop up in the middle of my screen
no photos of said window presented? i cant see them?
must be OSD? the monitor brain on screen display (menu)?
even with the DVI cable pulled?
only a monitor stated, w1907, no PC
some monitors have button lock
read the manual ?oops HP deleted it...
it tells you to push the menu key on the monitor for 10 seconds
and it unlocks. (4 buttons right side left button is MENU)
doom?
that power deal sounds super bad, like the power supply is bad.
if the monitor fails by its self not plugged it to a PC
then the monitors is bad.
try a reset on it? ( power off for 1hr, or off then plug in with power button held? or power on with menu held (wild guesses but common practice)
ok found your manual page 4-8 shows menu page advanced
list line in list factory reset.
but if the keys are dead, and power lamp failing
the power supply is no good or worse. worse is always possible.
and expensive
ever see the support page, read the guides
https://support.hp.com/us-en/product/HP-w1907-19-inch-Widescreen-LCD-Monitor/3709665/model/3709666
its over 10 years old now. 2007?
walmart has larger one for $50
cheaper that parts or repair this.... vastly
1helpful
2answers
Windows XP not fitting full on 22 inch computer screen
Your new monitor will show a "native resolution". In the instructions below, try that setting first. If that fails try other settings.
- Right-click on an empty spot on your desktop
- Chose "Properties" on the menu that appears
- Click the "Settings" tab (at the top right)
- Move the "screen resolution" slider to a different number
- Click "apply"
- See how you like it
- Repeat until you get a setting you like.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
