Question about APC BE500U ES 500 USB BACK-UPS 500VA/300W 120V (NEWITEM13161417) UPS System
APC ES- 500 Continuous Beep sound. I replaced new battery. But after 2-3 days again starts beeping. What?s wrong with this?
  • 84 Answers
SOURCE: In My APC UPS, continuous beep sound is coming
Unfortunately that signals an internal fault with the UPS and it requires immediate replacement / repair. Do not continue to use the UPS at all.
Posted on Mar 31, 2010
  • 19 Answers
SOURCE: APC Back-UPS ES 500: green light flashes&continuous warning tone
On this unit, the likely culprit is the battery and that it needs to be replaced.
With that, you may want to think about the pros and cons of replacement versus buying an entirely new unit.
This unit is a relatively low end ups and the surge supression uses MOVs that wear out with repeated absorption of energetic spikes. That's why the better (and higher cost) UPSs and surge suppressors don't use them. They're not really that good anyway due to their relatively high transient impedance. The better equipment uses a "transorb" -- basically a back-to-back high voltage zener diode optimized for low breakover impedance and high instantaneous power capability. Unless the transient exceeds the design parameters of the circuit, these do not wear out and do not degrade. That being said, I will assume that you would likely replace this unit with a similar one.
The flashing may not be the battery at all and may be the charging circuitry, thus your new battery may not live very long (half the life that you would expect.
Many batteries out there are refurbs and have issues as all used parts do.
If you contact APC, they will likely give you a 35% discount on purchasing a new product.
The difference in price in the battery replacement vs. ups replacement at this level may only be a few dollars more.
I promise that I am not a UPS salesman, I just deal with many on a daily basis; therefore I am giving my two cents to try to thelp you avoid problems a year from now.
Posted on Dec 30, 2009
Testimonial: "Outstanding answer with right amount of detail. I swapped battery with identical APC UPS that I have and vfd that battery was cause of warning tone."
  • 401 Answers
SOURCE: red light and beeping
change the battery
Posted on Mar 11, 2010
  • 608 Answers
SOURCE: What does it mean by the beep sound from the UPS ES 350 unit?
Ok, 3-4 years is a much as you can expect from an ups battery so replacement is indicated. The beeps are letting you know the battery is not able to keep up with demand. So either you have recently added to the system or the battery/s failing.
Posted on Apr 25, 2010
  • 8 Answers
SOURCE: Alternating green and orange light with constant beeps
Verify that the usb to ups cable is pluggled in properly. Also you may not have a good ground. Disconnect the ups and plug it in another outlet to test with nothing else plugged into it, to see if it still beeps. You can also try and upgrade the ups software from apc.com
Posted on Jun 25, 2010
Apc beeping twice every 2 seconds
The battery inside the APC is "weak", and the "beep" is telling you to replace the battery inside the APC, or, maybe cheaper, to buy a new APC.
Feb 03, 2014 | APC BACKUPS ES BE550G 8Outlet 550VA 330W...
APC UPS ES 500 series continuous beep sound and flashing green light
Hi Lasantha,
Check the battery in your UPS - it's most likely going bad and you will need to replace it.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
** If this helped - Give it a Thumbs Up :) **
Dec 03, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
A continous beep sound is hear in my ups..........wat shall i do now
Continuous beeping can be an indication that the battery needs replacing, especially if you have had this UPS for awhile
Feb 22, 2013 | APC Back-UPS ES 350 - UPS ( external ) -...
SO bad, and a bad response... I have 2 UPCs one started beeping for no reason, and will not stop...even when plugged into the wall with the battery disconnected... The other one is still silent. SO the...
These beep error codes may help you.
1. Four beeps every 30 seconds (On Battery LEDwill be illuminated)
This alarm indicates that the Battery Power Suppliedoutlets are now supplying battery power as opposed to power from the utility.If the UPS determines that the input utility power is unsafe for your computerequipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Battery condition hasbeen reached and that the UPS will soon shutdown. Once the UPS transfers to OnBattery operation, it can only stay on battery for a limited amount of time.The UPS will sound this alarm about two minutes before the batteries aretotally exhausted. Once exhausted, the UPS will shutdown and turn off itsoutput power to your equipment. If you hear this tone you should immediatelyshutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPSOFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overloadcondition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload was detectedwhile the unit was on-battery operation. This tone will continue to sound untilthe unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-powered outletsare overloaded.
6. Continuous Tone (On Line and On Battery LEDsflashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault hasoccurred.
Feb 28, 2011 | APC Back-UPS Pro 650 UPS System
After i switch on the ups there are continuous beeps with red light instead of the normal green. if i continue to use the beeping stops after sometime but the red light persists. But then again the beeping...
ups with 300 watts can only back up 1 computer, though it can handle 2 computers but not too long. your ups battery life span are good only for 2 to 3 years. for battery replacement you can visit the nearest service center and ask for battery replacement. it will not cost you much.
Feb 10, 2011 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
I have an APC XS 900 for about 1 1/2 now. I started getting a continuous beep with the overload light turning on. I could not get it to stop, even when the computer was disconnected. After reading the...
You need to reset the unit to recognize the new battery, I had same problem with one apc smart ups on the bench the other day.
On ours we had to turn off the unit unplug the battery wait 5mins
press the on key and hold for 20secs
reconnect battery
plug in to mains
and start as normal. We did this but still had very low battery time and the flashing lights, so we disconnected the comms interface, that sovled the problem.
It may work for your unit, suggest you check the manual before you try if you are unsure
Hope this helps
Thanks for using FixYa
Aug 09, 2010 | APC Back-UPS XS900 (BX900) UPS System
Apr 18, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
APC BE500U ES 500 USB BACK-UPS 500VA/300W 120V (NEWITEM13161417) UPS System Logo
2,014 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
