Question about Hotpoint NWSR483EBWW Electric Dryer
My dryer is getting electrical power. But when I turn the power knob onto ON, nothing happens.
    President:
  • 3,074 Answers
It may be the door switch, but if you hear a click when you push the start button then the motor reset button tripped. You should be able to set the dryer on its front side and see the motor reset buttons as there are two one trips one resets, push the reset in it should click and then plug it in and see if that helped. Hope this helps if not feel free to ask more info as I am more then willing to help Tim
Posted on Oct 16, 2010
Testimonial: "The actual problem was one of the wires that come out of the bottom front cover was broke. We spliced the wire, put the dryer back together, plugged i"
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Dryer quit in the middle of a load, pushed start button, hear an electrical buzz by the selector knob, nothing happens. tried another selection, nothing happened. checked lint hose & it was clear. is...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 24, 2011 | Frigidaire FDE336RE Dryer
Went to do a load of laundry, and when I turned the knob & pulled out to begin filling the water, nothing happened. Checked our fuse box, but that isn't the issue. Tried turning all knobs, and...
first off the dryer should be on a entirely different circuit... so i would plug something else into the washer plug such as a lampo and make sure you indeed have power... if you do you could have one of 2 problems ... either the lid switch on the unit itself has failed and you would have to gain access to it and it can be tested with a meter to see if it is bad.. you can also by -pass the lid switch with a jumper to check... if this is not the problem then you may want to take a look at your timer to see if it is getting power and nothing is burnt up... this will require taken the console apart to get into unit... remember always disconnect poweer before working with electricity.....be safe and good luck.....
Jan 03, 2011 | Washing Machines
Eurotech dryer. ON light flashes on and off, beeps once, and still flashes then nothing happens, dryer won't start. Help?
The problem is that you stopped a cycle before the program knob reached the "STOP" (12 o'clock on the knob). All you have to do is turn on the machine, turn the knob to STOP, and wait a couple of seconds. You'll hear a tone and the ON/OFF light will stop blinking. Turn the program knob to the cycle you want and- viola! you're good to go!
May 20, 2010 | EuroTech EDC158 Electric Dryer
I have a Maytag Performa electric dryer that won't start
you have an open thermal fuse.part no. la-1053,its kinda tough to install,i would recommend a qualified servicer
Mar 06, 2010 | Maytag Dryers
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
No electric to dryer,door light will not come on either when open
You must have a blown fuse. Check out this page I wrote on various dryer fuses and LOCATIONS
Note: A picture tells a thousand words right? Just being able to ID a fuse would be a plus and that is what I was thinking when I created the site. On this same site is how to get into your dryer, and Dead Dryer as well as other dryer wisdom.
Mar 26, 2009 | Dryers
Won't turn on when you pull the knob.
replace the timer it has a bad contact in it
May 19, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
Hotpoint NWSR483EBWW Electric Dryer Logo
331 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
