Plasma tv picture gone - sound ok. picture shadowy / blotchy
  • 3 more comments
  • suzaries Jun 03, 2008
    Hi. Its a 3 year old 42 inch Phillips. The model # listed in the manual is 37/42/50PF7320a/37 - hopefully that makes sense.
    Hi. Unfortunately, its not the settings. I should mention that my mother in law has had the tv on about 12+ hours a day for the last 2 weeks.
    We haven't added anything new, but there is a digital antenna, dvd player and wii. The pic is bad for all 3.
    The images are changing when I change to dvd, wii or change the channel on the tv.
    If there is a hardware prob with the plasma, do you know how much is usually runs to fix? I am going to see if my husband can check the voltage on the power supply too (he works on guitar amps so should have the equipment). Do you know of any place where I could get the schematic on Philips plasmas??
  • 3,037 Answers
Does it seem like that an image got burnt into the screen at all because this is a common problem with Plasma tvs especially with the same image being shown over and over.
Posted on Jun 03, 2008
  • Benjamin Patri
    Benjamin Patri Jun 03, 2008
    I'm thinking that the video processor is bad, so have your husband take a look at that first, but a lot of these tvs seem to have an overheating board that will bend and cause problems too.
    Here is a link to the service manual, hope it helps
    http://www.pcrescueoc.com/philips.htm
  • 407 Answers
Maybe you changed the settings on your tv by lowering the gamma or brightness
  • 2,323 Answers
A common failure on Plasmas is due to high heat on the Y sustainer boards.
If you could measure the voltages from the power supply to the sustainers assemblies, some video failures could be related to a lower voltage from the power supply to the main board as well.
  • Jaime Hernandez Jun 03, 2008
    If the brightness and contrast are set correctly to about 50% to start, you could increase them higher and see if that helps.
    If that did not improve the video quality, then more likely there is a hardware defect on your plasma.
    Sergeant:
    Champion:
  • 359 Answers
Do you have more info on make and model?
  • shane donegan
    shane donegan Jun 03, 2008
    what do you have connected to it?
  • shane donegan
    it seems that it has been overheated you may need to get a repair guy in.
Shadowy horizontal lines on plasma tv
Would have helped if you posted the make/model of the TV as well.
Apr 09, 2016 | Televison & Video
Plug tv in and comes on ok but picture resolution apears very slow
There are several possibilities here.
If the picture is very dark and blotchy you may have a bad X-MAIN (ZSUS) board.
It can also be the Y-Main board, but less likely, it usually fails in a different way.
Here are a few useful repairs for your TV we offer:
http://www.coppelltvrepair.com/search?Q=50PFP5332D&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
(Basically just a search of the TV model at the site to see what it comes up with)
Hope it helps!
Dec 06, 2013 | Philips 50PFP5332D 50 in. Plasma...
Plasma TV gave pop sound and no pictures except very dark shadows almost not visible
the back light went out the pop was either a capacitor aor a fuse blowing seeingas you sill have a shadowy picture it would most likely be the capacitor for the back light supply. Most repair shops should be able to replace the capacitor for you or if you feel like doing it yourself you willneed a soldering iron, solder, de-soldering iron or simialr, the repalcement part. to locate the blown capacitor just look for a burn part on the board.
Jun 30, 2011 | Televison & Video
Hi, Maxent P420142x3. Screen picture has gone....
my maxent p420142x3 i have sound but no picture any answers
May 19, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Samsung HPR-5052X Plasma issues. Recently started
If the picture os goint to lines right from the midpoint downward then most likely you will have to replace the lower y-buffer board part number BN96-02027A. The board is mounted on the left side of the plasma panel when you take the back off. The upper y-buffer board sounds like it is failing as well and this was a very common issue on the older Samsung plasmas. The part number for it is BN96-02026A. Please take a moment and rate my answer. Thanks...
Nov 26, 2009 | Televison & Video
Toshiba 50HP16 Plasma tv has sound, no picture. Screen is flashing like a camera flash....on-off at random. Volume works with remote. No menu. Screen flickers/flashes. Power light in front is green. TV is...
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Oct 07, 2009 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Tv turned off and wont turn on
If there is no picture and not even a hint of backlighting, it sounds like the plasma panel itself may have gone bad.
Mar 07, 2008 | Vizio P4 46 in. HD-Ready Plasma Television
Prima plasma 42
sir,,,kindly check out the chroma section,,,,,thnkss and hope too help you
Feb 01, 2008 | Televison & Video
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
