Question about Radio Shack Pro-94 Scanner
I try to reset my Pro94, turn off, press 2 and 9 and turn on .. then show "LOAD" in the dispaly and 22222 after ... I turn off and turn again ,,, The scaner get stuck in a strange trunking mode and i cant get out of it ....
    President:
  • 2,761 Answers
You need to press the 2 and 9 keys and hold them in while you power the scanner on. Once you do that the display should show CLEAR for about 5 seconds while it completes the reset function.
Bill B
Posted on Oct 16, 2010
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
Hi,how can i reset the language on my wmd960 hotpoint ultima,thanks
1. Switch on the power and when the language is displayed - press the child lock+ temperature+ spin buttons simultaneously for about 5 seconds. Release the child lock button when other languages appear. Scroll down using temperature button-until English is dispalyed. Select using child lock button.
Jan 14, 2011 | Hotpoint Ultima WF860 Front Load Washer
How do I reset it? Joekall@optonline.net
Turn the computer off.
Turn the computer on.
When it shows "press <BLAH> to enter BIOS SETUP mode",
press the <BLAH> key.
Select 'Load BIOS defaults'.
Select 'Save & Exit'.
If that resets it, stop here.
Disconnect the AC power.
Open the side-panel on the desktop case, and look for the 'RESET CMOS' label,
close to three gold pins that are in a row. A jumper will be connected to pins #1 and #2.
Move the jumper to connect pins #2 and #3. Count to 30.
Move the jumper back to re-connect pins #1 and #2.
Connect the AC power.
Jan 05, 2011 | Computers & Internet
My PRO94 Scanner beeps about 5 times after every transmission. I know that it can be corrected because it happened before but I don't remember how to do it. It had to do with pressing a button while...
To RESET your scanner:
- Power the unit OFF
- Press and hold the 2 and 9 keys while you power the unit ON
- "CLEAR" will flash on the display for about 5 seconds as the scanner clears and resets itself.
- Do not power the unit OFF until the CLEAR message stops flashing
NOTE: This procedure will clear (erase) all data that you have programmed into it, so be prepared to reprogram everything.
Need the manual for your PRO-94? You can download and print it, at no cost, here:
http://support.radioshack.com/support_electronics/doc61/61172.pdf
Bill B
Listening in since the 60's
Sep 20, 2010 | Radio Shack Pro-94 Scanner
Pixma 145 is regulerly showing E 2 8 ERROR. i bought it 3 month before. please solve the problem...
E28 is ink cartridge temperature rise error
Try to reset the printer like this:
With the printer powered off but connected to a power source , you must:
1. Press stop/reset button, and then press [ON/OFF] button to restart
2. Press [ON/OFF] again and then press twice the stop/reset button.
3. Press [ON/OFF] & Stop/reset button together, this time to enter the repair status and power lights will be green,
4. Press stop/reset button 4x and warning lights will be go out in [ON/OFF]button.
5. Turn off the printer.( it must be turn off) and then turn it on again.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5 Unplug cable power.
Aug 25, 2009 | Office Equipment & Supplies
Shift key stuck
If EXT is displayed showing you're in "Extend" mode, another way to shut it off other than pressing F8 again is to press the ESC key
Jun 24, 2009 | Microsoft Excel for PC
My "KDE19STA3" Kipor generator keeps showing fault "L&H Freq.What could be responsible and what can i do? It shuts down about 30seconds after dispalying the fault.
this is telling you that the power frequency is above or below the safe limit and so shuts down.
do not run a load but
press the function button and hold then switch on but dont start keep holding until ph2 or similar is displayed then start read the frequency and adjust the engine speed until it reads correct then try will full load and adjust accordingly 1 or 2 hz either way will be ok
Jun 16, 2009 | Kipor Electrical Supplies
There is no display
Hi there, what you need to do is reset the video display. Do this by following steps :-
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep once when you first press it, then again 5 seconds later. When you hear this second beep let go of the power button.
Step 3. Wait for your PS3 to start up.
Hope this helps
Mar 30, 2009 | Sony Playstation 3 (PS3) Console
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot...
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Mar 30, 2009 | Electrolux EW1000i Front Load Washer
Radio Shack Pro-94 Scanner Logo
81 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
