Question about Cameras
I have an intellectual speed dome camera. I am hooking it up to my dvr. The camera seems to get stuck when doing it's self check. The sreen keeps saying wait. I know about the protocol must match. I believe it is correct.
  • Ronya Krykowsky Oct 16, 2010
    G'Day, I would like to know what the protocol is. I have a diagram for this. There is a switch 1 and a switch 2. Switch 1 is protocol setup. First row is status. DIP1, DIP2, PELCO-D,DIP3,DIP4.
    BAud rate. Next camera setup, Then switch2 address, DIP1,DIP2,DIP3,DIP4,DIP5,DIP6,DIP7,DIP8.
    There are 28 selections. Should these switches be on or off. It is in colums. I need to know what to do. So, status ,Protocol, status Baud rate, Camera setup, and address.
    Camera setup is also DIP%,DIP6,DIP7,DIP8. Please let me know.
    Thanks
  • Ronya Krykowsky Oct 17, 2010
    What ai would like is a proper manual. Do I need to set this camera at all for this Ip protocol. All I want is to have this camera work . There is a switch 1 and a switch2 . How are these switches set?
    The first is protocol status. There are 4 selectons DIP1 DIP2 DIP3 DIP4. Status, Protocol,status, baud rate. The next set is camera setup Status,camera. DIP5,DIP6,DIP7,DIP8. This I beleive is make. This is all one switch. The next switch is #2. This is the address setup.
    DIp1, Dip2,DIP3,DIP4,DIP5,DIP6,DIP7,DIP8.
    What do I do? I would like to know what all this means. I am getting very frustrated. The manual is a trans lation I think from chinese. Please help. My DVR isa 4 channel H.264 video security (model #Lion -4500. The camera is a Intelligent Dome Camera. CCTV. This all I know. Purchased in the states. Again please help.
    Thanks Ronya
  • 3,083 Answers
It might be one of two situations I can think of. First of all, you're right, it could be an incompatability issue between the dvr and the camera. You can try the camera on another dvr to see if it connects with another brand. The other problems could be a software glitch, hanging up the connectivity. In this case, the software would have to be rewritten, but since there aren't many complaints about this on the net, I'm doubtful this is the issue, and lean toword the incompatability issue.
I would contact the manufacturer and see if they have any information about incompatability issues, or a suggestion to get your dvr to work.
Good luck, and hope this helps.
Posted on Oct 16, 2010
I have two camera's hooked up but i cann't get tem both on at once what am i doing wrong?
What DVR system are you using? Are they connected to the back of the DVR properly? Check your connections at the DVR.
if your DVR system came with a mouse, right-click on the screen choose the icon with multiple screens, and then if you want them to alternate, click on "start tour".
May 25, 2014 | SWANN Home Security
Cnb dvr password reset
Welcome To CNB Technology.
www.cnbtec.com/en/html/support/faq.php?classify=B
Ex-factory ID and Password. Ex-factory ID and ... When running DVR program, an error message comes up and the program stops. Check if the driver is installed ...
CNB DVR hard drive failure/password reset - • CCTV Forum
www.cctvforum.com/viewtopic.php?f=3&t=45061
Mar 2, 2015 - 11 posts
Hello all, I purchased/had installed for my home a camera security system using theCNB HDE2424DV and Nuvico dome cameras. It has 8 ... CNM Secure Primus (8ch) password
Feb 13, 2013
Is Q-See Equipment any good?
May 1, 2012
CnM Secure 4 Channel H.264 DVR
May 5, 2011
I need help selecting a DVR
Jan 18, 2010
More results from www.cctvforum.com
Feb 14, 2014 | Home Security
How to hook up audio
Connect a microphone and enable the audio. It should all be in the settings. Check each camera to make sure audio is enabled. Usually it is off by default.
Jun 24, 2013 | Zmodo dvr-dk41103-1tb cctv 4 ch home...
I need a converter that will allow me to hook up the rj12 cables to the coaxial connections on a 16 channel revo dvr
hi;
you wan to hook up coaxial to rj12 ,if you you do that the wire of rj12 has not to exceed 3 meters
cause camera signal (video) to become weak. Camera Video signal has to be fed only to coaxial cable, coaxial cable has an insulation to prevent interference.
so if you want to hook up be sure put a shielded wire.
thanks......hope this help.
Sep 03, 2011 | Revo America Indoor Dome Security Camera...
Sentient 250GB DVR-RW CCTV N63HH - recording for longer peroids
Just reduce the frame rate slightly on each camera or the record quality and it will increase the data retention period.
Jun 14, 2010 | Dome 4 CCD CCTV Camera Surveillance...
How to control panasonic wv-cw960 through controller wv-cu161
how do i control my speed dome cam wb cw 960 connected to wj rt 416v, now that i dont have wv p416e 4 channel card in the market. i need to add rs485 cable but is there a connection port or do i need to add a hub i am talking about adding 3 units 960 units. pls advice.
Jan 08, 2010 | Panasonic WJ-HD316/6500 Series 16 Channel...
Vcr picture problem
clean the heads. check out my tip
Nov 02, 2008 | Orion VR213 VHS VCR
Cannot view replay
It has something to do with the software and hardware as well.
But not the monitor that is trouble you.
Mar 30, 2008 | Computers & Internet
Cameras Logo
27 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
