Question about Kenmore 43142 Front Load Washer
What could be broken on my kenmore frontload washer when it spins, there is a really big knocking sound, and it's like the barrel is off track kinda????
    Sergeant:
    Champion:
  • 277 Answers
Sarah,
How old is you machine? You would need a repair person to open up your machine. But if it is under waranty, get a sears guy to open it up.
If not under warranty, get someone you trust and you know what he/she is doing.
Are you in the GTA area, if so send me a note
bweazer at yahoo dot ca
Posted on Oct 16, 2010
Water is left in the barrel of frontloader
With unit in spin cycle, check the drain hose to see that water is dispursing into the drain. If there is no water coming out of the hose, you most likely have a bad water pump. Need to replace. Best of luck.
Aug 07, 2012 | Kenmore Elite 45986 Front Load Washer
I have a kenmore he elite frontload washing machine. Model no 42922. It has been knocking loudly on the spin cycle (and getting worse) and the last load I washed had bits of rubber seal?? in it?
you have a broken spider gear,most of the time it's caused from using to much detergent,it eats at the gear and basicly it's time for a new washer,the part is close to 500 dollars and that's not counting labor
Jan 19, 2011 | Kenmore Washing Machines
Kenmore front load washing machines knocks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 25, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore clothes washer makes a knocking sound at
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 05, 2010 | Kenmore 22422 Top Load Washer
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
Kenmore front load washer that's noisy when it spins
on most kenmore front loader after some time the bearing start to wear and the washer will get louder and louder,it is a big repair job!-mike
Mar 23, 2009 | Kenmore HE2 Plus Front Load Washer
Frontload washing machine makes noise during spin cycle
call sears 1 800 4myhome they can walk you thru some troubleshooting. First thing pull back the rubber ring between door and barrel to see if anything like pens etc feel into the gap underneath. If not call for troubleshooting. Get a plan with sears then wait 30 days and call in the problem. Fix will cost less.
Mar 22, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore frontloader washing machine making roaring
Your rear bearing is bad. Check warranty to see if rear tub is still covered.
Mar 08, 2009 | Kenmore 44102 Front Load Washer
Broken Washing Machine
frontload or top load frontload,,remove debris from inside pump,, top load , coupler problebly broken,
Oct 11, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Front Load Washer Problem
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
Oct 27, 2007 | Kenmore 44102 Front Load Washer
Kenmore 43142 Front Load Washer Logo
73 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
