Question about GE Refrigerators
I came home tonight and there is like a burnt industrial smell in the fridge and the things in the freezer are defrosting. I was only gone for about 2 hours. The fridge does not seem to be running. It is a side by side and only about 2.5 years old.
    President:
  • 1,891 Answers
Either the fan has ; burned out or the main board has . in either case it will have to be replaced . mm model # needed to help more, and you need to ck for the smell it could be the fan under neath or the fan in the freezer . and if the board ther is a plate on the back to remove and the smell will be there .. do un plug unit before getting into these . mm
Posted on Oct 16, 2010
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Jul 25, 2012 | Whirlpool Refrigerators
My whirlpool fridge similar looking to Whirlpool GR2FHMXV Top Freezer Refrigerator has been making a big bang noise many times in a day. Tonight it has a burning smells. Please advise?
the banging and crackle noise can be from the defrost element in the freezer side as it heats up it melts the ice on the evaporator it can be a bit nosy. there shouldn't have a burning smell tho get it checked out
Feb 04, 2011 | Whirlpool GR2FHMXV Top Freezer...
Phillips whirlpool built in fridge /freezer smell coming from the fridge section,we have tried various things but the smell still persists
Could it be that there is degradation of the plastics due to heating of the defrosting coils or is it the smell off leaked gas.
Remove all the food stuff from the fridge and clean, wash the inside throughly. Now restart the fridge and after aboutone hour check for smell, continue this till you notice, if the smell comes in after about 10 hours then you must look into the defrosting heater for any traces of material on it causing the smell on heat.
Aug 30, 2010 | Whirlpool Refrigerators
My fridge stopped working. First there was a burning plastic smell, then everything in the freezer defrosted even though the fan kept turning. It sounded normal. There was no frost on the back wall of the...
A burnt plastic smell indicates a failed component. Start where the odor was the strongest and locate the failed part. The hard part is determining the reason for the failure as just replacing parts will not correct the problem. Look at the start relay on the compressor or the defrost components.
Eric
Jan 24, 2010 | Kenmore Refrigerators
Samsung fridge freezer
sounds like the defrost thermostat is the problem. since it's located in the back of the fridge, behind the access panel, i would have a technician look at it.
Sep 13, 2008 | Refrigerators
THE FRIDGE OF MY FRIDGE FREEZER HAS STARTED TO FREEZE UP
is the fan running if so suspect a stuck timer, thermostat (cooling)
if fan doesn't run suspect defective defrost thermostat(some manufacturers wire the fan with them) or a bad defrost element if you see glass chards or burnt smell in freezer section.
thats all i can think of now. hope to se of some help
Apr 18, 2008 | Refrigerators
BEKO FRIDGE FREEZER
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 | Freezers
Refrigerator Smell
Is the problem more in the freezer than the fridge section. If it is it is possible that on a defrost cycle the heaters which warm the coil may have warped and ar heating something they shouldnt. Another possibility is if there is something in the condensate tray (where the water collects) or something touching the compressor which runs very hot, or even the compressor relay if it is a 'plastic' smell. Smells are notoriously bad things to trace as engineers normally turn up when the smell is either gone or so faint as to not to detect. All I can suggest is trying to narrow the search area as much as you can and hopefully youll find it. Hope this is of some help.
Sep 13, 2007 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
