Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The pilot lights are clicking with a spark on each burner but none of the knobs are not turned on, they are only creating a spark and a non-stop clicking noise.
    Problem Solver:
  • 5 Answers
You have a short in your wiring system, you are probably best to call a technician.
Posted on Oct 16, 2010
We are cranking up this BRAND NEW Vulcan flat top. Weh have the convection oven below up and running, but we can't even see a pilot light for the flat top. Advice anyone? Culinary-yours Chef Geir
older ovens have pilots but the newer machines are electronic ignition,there are ignitors in the oven and electrodes or ignitors on the top burners,when you turn the knob for the burner you should hear a clicking sound and see a spark around the burner,that's what lites the burner,the gas comes in and the spark ignites it,i don't know much about your machine but it can't be any different from other stoves.if none are sparking there should be a spark module in there or they could have separate modules,if you send the full model number i can look it up for you
Oct 30, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
I have constant clicking after turning off the burner. It will light but the clicking doesn't stop when the burner is on or off.
electronic pilot switch is shorted. should be 4 of them. they are located on the valve shaft directly behind each burner knob, just inside the burner valve cover
Feb 28, 2010 | Kitchen Ranges
How do i start the pilot light on a JGBP28wek6ww
That model is an electronic ignition, ther isn't a standing pilot on it(no liitle flame that stays lit). Light the burner by pushing in on the knob and turnlig to "LITE" position, you will hear a clicking noise the sound of the electric spark igniting the burner, turn the knob to adjust the flame size. Keep in mind that all igniters spark whenever any of the knobs are turned to the "LITE" position. Good luck !
Nov 30, 2009 | Televison & Video
Pilot on GE stove keeps popping non-stop
As far a "popping" do you mean the igniter on the cook top "clicking"? Did you clean the range and use too much water? If water gets into the igniter switches they will short out and constantly click. Also if the polarity at the electrical plug you can get what is called "ghost spark" so make sure that the polarity is correct at the electrical outlet. Each gas control valve has a switch that turns on the igniter when the knob is in a certain position and they are all wired in a sequence. One of those switches may be shorted out or have a loose wire(range dis-assembly required to inspect). Do you visually see a spark at the electrodes of the burners or do the burners ignite? If you cannot see the spark then there may be a grounding issue and possible loose wire.
Sep 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Electric spark for gas range burner is non stop
Turning any knob starts the spark via a switch behind each which should disengage when the (any) knob is turn further.
One of your switches is stuck.
I think you should be able to remove the range-top for access and find the offending switch.
It is probably gummy from a spill and is no longer in solid contact with the cam that operates it.
A solvent/lubricant such as WD-40 sprayed on the plunger of the switch once you can see it and operating the knob back and forth should free it up.
It might be wise to turn off the gas supply while tinkering with the range - blow your house away and the range won't matter. :-(
Jun 19, 2008 | Viking VGSC306-4B Gas Kitchen Range
Gas stove top not lighting - gas is on/electic to appliance is ok
Is it a (relatively) new stove - i.e. piezoelectric spark igniters?
If so, is there a "lite" or "pilot" (or some such) position on the knob? On most stoves you have to turn the knob to that position, it starts clicking, you may smell a little gas, and then it lights.
Is that happening?
When you turn it to the lite position, can you see a little spark in burner. Often these igniters stop working and need to be replaced.
Let me know.
Mar 13, 2008 | Kitchen Ranges
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
167 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
