Question about Xerox 5830 Copier
Xerox 5837 with 08-310 Error
Have an 08-310 (Paper Jam) error on a Xerox 5837. Have gone through all the normal procedure to remove any visible paper, have even emptied all the paper trays!, still no joy. Can anyone suggest a solution. Is it possible that there's a small piece of paper stuck somewhere inaccessible? or a sensor problem? Thanks
  • 239 Answers
On this model anything is possible.
If the machine exposure level is not "Correct" or gets out of balance, a jam code can appear such as this. It would take a trained person to get into diagnostics and view the NVM settings to check the values to see if they are in balance and need to be reset back again to normal.
Depending which tray is used, bad feed rolls can cause these types of jams.
A stuck registration solinoide can also cause jams such as these.
On this machine there is a vacume fan at the lower back, if it sticks or turns slow, it can create many frustrating jams, even on the vacum belt transport.
The machine has upper registration rollers, sometimes these rollers can get stuck and bind, causing these types of jams. The lower rollers are black and larger in diameter, the upper rollers under the develor housing are smaller in diameter.
There are many more areas that can cause jams on this model. For what is understood with this error code, these are the most common. For further explination of other jams we would need more information, which tray is used, exact messeges, ect..
Posted on Oct 26, 2009
A minha maquina xerox 5837 esta dando o erro 06-340 nao sei o que é isso.Estou procurando todas as forma de busca, e nao encontro nada. sera que podem me informa os procedimentos para o reparo
Posted on Mar 23, 2009
    Problem Solver:
  • 10 Answers
If you donot find paper in the machine check for a stuck actuator or a bad sensor.
Posted on Jun 07, 2008
Paper got jammed. Removed. Still says paper jam, but I can't see any. What should I do next?
Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam,+but+there+is+not...
iFixitThere is no paper jammed anywhere! each time I would finish with the steps and ... I have to turn off and turn on the printer to get it going again. ... and the grinding sound and the paper jam message still comes up. i am going to try .... well no luck Iremoved ink and they are not dry - new- and now it says paper jam and not so ...
Fixing Brother Printer "Paper Jam" Error with No ... - YouTube
? 1:54
https://www.youtube.com/watch?v=SqWNFVIR6JA
May 30, 2014 - Uploaded by Refresh Cartridges
Fixing Brother Printer "Paper Jam" Error with No Paper Jammed.... problem occurred again. i try this many times but the problem is still in there. ... There was paper jam front rear on my brother j450dw that wasn't going away, that was ... How to remove jammed paper HP LaserJet Professional P1102 Printer ...
How to fix a printer paper jam. - Computer Hope
Dec 03, 2015 | Office Equipment & Supplies
The printer ran out of paper, when we refilled it, it says there is a paper jam. We removed all paper that was visible and the error will not go away. Please assist. Thanks.
on removing the paper a bit of paper may have teared and may be present inside OR the sensor at the delivery area may not be recognised
Jan 13, 2011 | Xerox WorkCentre Pro 123 Copier
Xerox M15i has a paper jam 2 error, how to fix
Hi, open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
The fuser itself probably needs rebuilt or replaced.
Take care
Jul 19, 2010 | Xerox WorkCentre M15i Laser Printer
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
Paper jam
I had the same problem kept getting an error something like Jam at Exit Door Open Door A. When I looked at the top of the where paper normally comes from and flipped it open I found a super crinkled piece of paper, which once removed cleared the jam.
May 03, 2008 | Xerox Phaser 6180N Laser Printer
157 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
