Question about Sharp Aquos LC37D44U 37 in. LCD HDTV
I have a lcd 37 inch lc-37d44u the green power light keeps falshing
  • 11,361 Answers
It may be in the safety shutdown due to shorts circuits in the power supply or in the backlight inverter board. You will have to open it up and check.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 16, 2010
I have a sharp aquos lc-37d44u and I have the blinking green power light problem I replaced the backlight inverter board still nothing and the only thing i.think it could be is the lamps but Don't no
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. Check all the CCFL lamps for darkened ends. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 27, 2016 | Sharp Lc-37d44u LCD Tv
Sharp tv remote control problem
Keep your mobile camera on press any key from remote you will get flash light in mobile.It means remote is ok.
Press On/Off switch from LED Tv and checked tv is on or off.
If Green light is blinking but tv not getting on follow as per attached file.
Mar 31, 2015 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Tv diagrames
Schematic diagrams are in PDF, and cannot upload by this window. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 22, 2013 | Sharp Aquos LC37D44U 37 in. LCD HDTV
37in sharp lc-37d44u, green flashing power light, will not turn on.
There two possibilities, one that you have bad invertor unit, two you have one CCFL (backlight lamp) went dead.
Nov 29, 2009 | Sharp Televison & Video
Green lights flasghing, no picture
Tries unplug,replug tries on/off for awhile might work,not than the backlight board it dead.
Sep 22, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I have sharp 37 inch LC-37D44U MY PS3 is not working with it it green lights keep blinking power light and OPC. BUT THE HDMi ports work beacause i checked it with other devices. so i dont know why its not...
Does this happen when you input certain signals to the HDMI2_bing.gif ports? Or all signals (e.g. 1080i, 720p, 1080p, etc.)? And which ports are affected - side HDMI, rear component, etc.?
I had this issue and Sharp sent out a local repair tech to install a new main circuit board, then two weeks later, a new side board (where the side inputs connect into the system)... their first visit allowed my TV to accept signals in the rear HDMI ports (all signals worked well), but then I couldn't get a signal processed via the side HDMI port. At first, just 1080p would not display (caused the OPC/power green light blinking), and after a few days, any signal hitting that port would cause the error lights to come on. But as I said, eventually, a new side board resolved that issue.
Sep 11, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
LC-C6554U HDTV AGUOS 2 GREEN LIGHT FLASHING, NO PICTURE NO SOUND
Did you ever find a solution to your problem? I have the same set doing the same exact thing.
Thanks
Jul 30, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp 37 inch aqous tv power button blinking red
If the blinking light seems to be blinking in a pattern, then it is an error code. The end result in any case, is the main power supply is not functioning properly, or the backlight power supply has a problem.
Nov 13, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC37D44U 37 in. LCD HDTV Logo
610 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
