Question about Samsung RF217ABRS (197 cu ft) Bottom Freezer French Door Refrigerator
Ice underneath crisper building up then dripping on wood floor. Ice is one eighth inch thick. I have French door samsung fridge
    President:
  • 1,891 Answers
Clean the drain in the botom of freezer and remove the ice . this should control the problem .. mm
Posted on Oct 16, 2010
I need a right hand crisper draw for a Samsung refridgerator model srf680cdls
Hello Kate Nicholas,
Your model srf680cdls... does not respond domestically in the USA... If you provide your ACTUAL PART NUMBER I could attempt to check CRISPER availability ... here (you appear to have an "AU" model.
Just looking around the large plastic body would appear to cost about $60 (USA)... I'm pretty sure we share the MANY of the same internal part numbers..
http://www.woolleys.com.au/?gclid=CPqQzujj184CFQYdaQod1n0AIw
BigWarehouse Spare Parts samsung crisper drawer
Sydney Only Samsung SRF680CDLS 680L French Door Fridge with Water and Ice...
http://www.ebay.com.au/itm/ws/eBayISAPI.dll?ViewItem&item=121998338668&catId=20710&item=121998338668&mid=503315&sdc_id=1081525136346&sortbid=15&rmvSB=true
Samsung 28 15 cu ft 4 Door French Door Refrigerator in Stainless Steel...
http://www.appliancepartspros.com/samsung-case-veg-assy-da97-08437d-ap5805507.html
Aug 23, 2016 | Samsung Refrigerators
Ice buildup in bottom of freezer compartment
Here's a link to a great website that will help you understand what might be causing your freezer to have that ice build up. I could explain it here, but if you look at this link, they've already done a wonderful job.
http://www.appliance411.com/faq/defrostproblem.shtml
Jun 08, 2016 | Samsung RF4287HARS French Door...
Water falls into ice tray and freezers.
If you have a Samsung French Door (as I did) you'll find the solution here: Samsung Refrigerator Leaking Into Crisper Drawer Floor
Mar 23, 2016 | Refrigerators
My Whirlpool refrigerator, model GT22DMXGW00, leaks. Water is accumulating in the bottom-underneath the right hand side crisper. It then drains out onto the kitchen floor. Some is freezing too. It is...
check the ice door flap where ice drops into a glass.sometimes the flap doesn't close completely and allows heat to enter threw the flap.this causes frost to build and melt thus you have water you can't explain. hope this helps.
Dec 11, 2014 | Whirlpool Refrigerators
Why is there ice in the bottom of the crisper?
Freezer /fridge water/ice in fridge
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Sep 07, 2014 | Samsung RF217ABPN Bottom Freezer French...
RF261BEAESP
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
Apr 15, 2014 | Samsung RF261BEAESP 25.5 cu. ft. French...
What's your problem?ice buildup under french drawer refrigerator
It could just be condensation, especially if you live in a humid area. I'd consider adding some silica gel packets (the kind you find in shoeboxes,) to the place where the ice is building up and see if there are holes in the ice where the silica is. If so, it's moisture-based, and short of installing a dehumidifier in the house or running the AC constantly, your best bet is to invest in a thick rubber mat, like the kind offices have at the door, and place the fridge on it, possibly with a small one-inch-thick block of wood under each foot. That's what I had to do and to my surprise, my power bill went down. It turned out that the rubber mat caught the condensation and let it evaporate, plus the wooden blocks gave the refrigerator coils more ventilation, which made it run more efficiently. It was like a $5 difference per month on the electric bill, so definitely worth a try, plus if the rubber mat is rectangular, it'll protect the patch of floor in front of the fridge from any accidental spills.
Aug 29, 2012 | Cell Phones
My whirlpool French door fridge is leaking all over the floor. The drip pan underneath is bone dry. I can't find the drain hole inside the fridge to see if it is clogged. Is letting it thaw for tw
there is a water tube connection at the bottom of door on hinge side that has a spring and allows it to swing with door. it also has a fitting there so the door can be removed.it is the tube running inside the door to the ice water dispenser. if it has one, it can leak at the fiting
Jul 07, 2012 | Whirlpool GX5FHDXVY Stainless Steel (248...
I have an LG fridge (LG LRBC22544) that collects water underneath the crispers. It freezes (almost 1 inch thick) and then melts. Once it melts, then it leaks out the door. This reforms every 3 weeks or...
I have had the same problem. In my case, its the little water tank behind the left crisper. The tank has cracked (twice now) which means replacement (again). The water leakage gets so bad that it leaks into the freezer causing ice up problems in the rear.
Apr 27, 2010 | LG LRBC22544 Bottom Freezer Refrigerator
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Samsung RF217ABRS (197 cu ft) Bottom Freezer French Door Refrigerator Logo
532 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
