Question about Mitsubishi WS-65907 65" Rear Projection Television
The tv will instantly shut off after its powered on. I did a self check by holding the menu and input buttons for 5 seconds and the green power light in front blinked twice then paused, and blinked twice again.
    Genius:
  • 1,030 Answers
This is error 22. which is a short curcit protection error. the first suspects in this case is the convergence ic (stks) these are supplied by 24 and -24 volt lines. these short and shut the set down.
Posted on Oct 16, 2010
Tv turns on and back off
Most of these sets have a self check----if Green power light comes on for a few seconds and goes off on the front of the set press and hold both the menu and input (source) buttons at same time for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it for a total of 5 times.
Let me know if you get a error code and what it is.
Unplugging power from the set clears the error code so if that has been done you will have to try to turn set on, let it fail and then do the self check again.
Dec 02, 2012 | Mitsubishi Televison & Video
I have a Mitsubishi VS-50501A Rear projection TV. When I push the power button the green comes on for a few seconds then goes out. The TV will not power on.
This one may or may not have the self check:
when green light goes out on front of set press menu and input (device) buttons at same time and hold for at least 5 seconds and let go: if it has self check power light should blink a two digit error code and repeat it several times.
If no response it indicates some problem in main power supply (set is in shut down)
I need to know what skills you have; what I have seen mostly in these early sets is bad solder connections that develop on main boards; I can tell you where and what to look for but it involves getting at the boards and being able to solder.
Before you rate this information let me know what you find and remember I am here to help you.
SD TECH
Aug 15, 2011 | Mitsubishi Televison & Video
Tv automatically powers off by itself within seconds.
This model has a self check: with the set plugged in turn it on--green power light comes on and a few seconds later goes off.
On front of set press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Apr 11, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
MY TV WONT STAY ON. WE TURN IT ON IT TURNS OFF. WE DID THE RESET SYSTEM BUTTON.
when it shuts off and power light goes off do the self check this model has.
When green light (power) goes out, on front of set press and hold both the menu and Input buttons for at least 5 seconds and release both.
WATCH THE POWER LIGHT closely, the light should blink a two digit error code.
for example, 2 blinks, 2 blinks and a pause, it should repeat the code at least five times.
Let me know what code you detect and I will tell you what it means.
SD TECH
Feb 12, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I have a 2002 65" Mitsubissi projection TV and it
When it shuts off and the green light goes out do this:
On front of set press and hold both the menu and Input buttons (device) both at the same time and hold for at least five seconds and then release both.
This is the self check the set has.
The power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
let me know what error code you get and I will tell you what it means.
I am in California and online now.
SD TECH
Feb 11, 2011 | Mitsubishi WS-65613 65" Rear Projection...
My TV just shut off and will not turn on again.
If green power light comes on for a second or two and goes off, do the self check the set has.
On the front of the set press and hold BOTH the MENU and INPUT buttons at the same time and release them after 5 seconds or longer.
Power light will blink a two digit error code about 5 times. 2 blinks, pause and 2 blinks is typical one seen most.
Let me know by replying to this solution what error code you find and I will tell you what it means.
SD TECH
Jun 23, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Tv WONT STAY ON
When the power light comes on and then goes off perform the self check feature the model you indicated has:
On the front of the press and hold both the MENU and INPUT (DEVICE) BUTTONS both for at least 5 seconds and release both buttons.
The green power light should blink a two digit error code--most common is 2 blinks, a pause and 2 blinks.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Power shuts off 1 second after tv is turned on
Good Day,
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source)
1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC).
2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB.
I hope this was helpful, BIG IRISH.
Dec 16, 2009 | Mitsubishi WS-55819 55" Rear Projection...
When I power up the TV, I hear a click and the green light turns on, but seconds later, it clicks off.
try self check==when it shuts off press and hold both menu and input buttons on the front of the set for 5 seconds and release both====power light should blink a two digit code===most common is 2 blinks and then 2 blinks, let me know error code and I will tell you what it means====it should repeat the code 10 times
SD TECH
Oct 17, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-65907 65" Rear Projection Television Logo
100 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
