Question about Amana ABB1927DE Bottom Freezer Refrigerator
Refrigerator is not working but we can hear the motor running for the freezer. What could the problem be?
    President:
  • 1,891 Answers
If the unit only has one motor then what are we hearing . . I would look for ice buld up in back of freezer and if so there is a defrost problem causing it . this will block the ari to the ref side .. mm
Posted on Oct 16, 2010
My freezer is not blowing cold out. I hear the compressor running but its not getting cold
most likely bad evaporator fan motor located behind the wall in the freezer,when you open the freezer door you should hear the fan blowing in the freezer unless it's in defrost,if you don't hear it check it in 45 minutes if still no fan it's bad.
Oct 03, 2014 | Frigidaire FRS3R5EMB Side by Side...
How to check fan motor funtionality of PFCS1NJXB SS?
It probably has two fan motors. One that keeps the compressor cool and one in the freezer compartment that blows cold air out into the freezer and into the frig. You should be able to hear the motor running and feel the air coming out the vents when you open the door of the freezer. The fan runs all the time. If you do not feel or hear, the fan is not working. The one on the compressor, take the cover off the back and you can see if the fan is turning. It runs all the time also.
May 06, 2014 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
My refrigerator is not getting cold
Is the freezer freezing? Do you hear a fan motor running inside the freezer? If the freezer fan is working and the freezer is still getting cold, do you see allot of frost on the back wall of the freezer?
Freezer not cooling at all - t-stat or compressor would be where to check next
No fan running in freezer and freezer is cold - bad evaporator fan motor.
If fan is running and you have heavy frost on the back wall of freezer - unit is not defrosting. could be defrost timer or defrost t-stat
Mar 12, 2013 | Amana Refrigerators
Refrigerator is not cooling (freezer works)
check your evaporator fan motor open the freezer you should hear it running if it doesn;t run is just going to work for a short time.
Jun 15, 2011 | Kenmore Top Freezer Refrigerator
Westinghouse fridge/freezer (freezer on top) has suddenly stopped working (purchased December 2003). I can still hear something running (motor?!), any suggestions please?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 07, 2010 | Westinghouse Refrigerators
Refrigerator wont kick on. Freezer seems to be working, at least the food in the freezer hasnt started to thaw yet.
the refrigerator gets its cold air from the freezer compartment via ductwork between the freezer and refrigerator. a fan in the freezer circulates the air to the refrigerator. your fan is probably not functioning correctly or not it all. you should hear it running in the freezer compartment. if you do not hear it running it is either snagged on some ice or the motor itself is burned out and will have to be replaced.
Mar 17, 2010 | Refrigerators
My refrigerator was working then we moved it to another apartment now it is not getting cold.
Good day,
Assuming the lights are working, and you hear it running,
Check the most common problems first.
1. Open the freezer door and see if you hear the fan motor running. If not remove the rear panel in the freezer panel and inspect motor.
2. Most common, another fan motor motor in the bottom rear behind the rear cover was jammed while moving. Remove rear cover, inspect, and repair.
3. Check for wire damage elsewhere in the bottom area where that motor is located.
4. Make sure controls are on and set to normal.
Nov 05, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator is not getting cold although the freezer appears to be working fine
can you hear the evaporator fan motor running in the freezer? this fan motor pushes the cold air from the freezer to the food section to keep it cold. you may have to replace the evap. fan motor. also, check for any kind of ice build up around the evap fan motor.
Oct 11, 2009 | Amana ABB1927DE Bottom Freezer...
Inside refrigerator is warm - but freezer seems to be working.
friend .
you need to have check of your condenser.
either the condenser has gone down.so the gas is not there to cool.
see that u can hear the sound of motor running.if it works.
i am sure the cooling problem may be due to this.
Mar 28, 2009 | Kenmore 14.8 cu. ft. Top Freezer...
Freezer works but refrigerator is staying at 60 degrees
listen to hear if you can hear the evap.fan motor running.check to see if you have any frost built up on freezer back panel.if so you have a defrost problem.clean coils under ref. and make sure condensor fan motor is running,that is by the compressor.
Mar 06, 2009 | Frigidaire GLRS263ZD Side by Side...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
35 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
